Steve1978 Senior Member T6 Guru 14 Jan 2023 #1 This is a broken wire on the negative terminal. No idea what it’s for but it’s been like this for years. Any ideas
Pauly Senior Member VCDS User Admin Moderator 14 Jan 2023 #2 Thats the negative shunt on the battery, it measures current flow in and out of the battery as part of the charging regime/start stop system
Steve1978 Senior Member T6 Guru 14 Jan 2023 #3 Ahhh that will be why my start stop always says not possible! Lol Any idea if that cable can be repaired?
Dav-Tec Audio, Security, Brakes, Suspension & More VCDS User Trade Member T6 Legend 15 Jan 2023 #4 Sure can just needs a new plug and connectors on it buddy
Mooncat The Members T6 Guru 15 Jan 2023 #5 You can push the pins out of the connector - I've managed to solder wires directly onto these and refit them before. Or buy a new plug ref above. Don't forget to start a new thread claiming you've found a way to disable start/stop and get loads of likes!
Dav-Tec Audio, Security, Brakes, Suspension & More VCDS User Trade Member T6 Legend 15 Jan 2023 #6 Mooncat said: You can push the pins out of the connector - I've managed to solder wires directly onto these and refit them before. Or buy a new plug ref above. Don't forget to start a new thread claiming you've found a way to disable start/stop and get loads of likes! Click to expand... Sorry if I've missed the sarcasm (more than likely). You can disable start stop on the T6 and T6.1 via coding
Steve1978 Senior Member T6 Guru 15 Jan 2023 #7 Ah but you have to pay someone to do that. This is free! Snip snip!
