Can we see a before and after vid pls
A few people have asked. I will pop one up when I get to my next jobCan we see a before and after vid pls
You need to upload your vid to a hosting site (e.g. YT) and then post a link to the vid on here.Not sure how to upload videos
Where is that from?
Tescos. 5cm thickWhere is that from?
And presumably a new set of underpants as well.The swmbo a new to her Kia sportage after I mistakenly pulled the Bonnet release handle instead of the filler cap opening lever whilst I filled her old car with diesel.
Now in my defence it shares a similar location to where the filler cap release is on my old ranger pick up.
Who knew you could find this out in the fast lane of the M27 at 70mph. This has been a very, very, very expensive mistake. Oh my days!!!!
This is a write off hence having to buy my. Way out of trouble.lol. Wasn’t too bad as there was a large gap to see under as the hinges gave up on life about a nanosecond into the excitement.
Well that’s what I thought. The force of the bonnet opening at considerable speed cause the hinges to pull the bulk head mounting area out and also damaging the bottom of both a pillars. Body shop quoted even with me supplying all the bits over £2k. It’s a 100k miles 13 plate Kia. And it would have to be set as a cat s after repair. Just not worth the effort to do. Swmbo has a newer nicer car now and I have less numbers on my bank balance because I’m an idiot.Wow, have the bonnet actuators just let go? Should be an easy repair.
Yes it could have been soooo much worse. Very lucky indeed even had a nice policeman promptly pull in behind us as we nearly made it off the motorway and lend me a crow bar to make some fine tolerance adjustment to the now not so hingey hinges.Wow, just goes to show how powerful forced air is and how flimsy new cars actually are. Easy mistake to make. Main thing is you are all okay and no one was hurt.
We had this on a customer's car , safety catch was seized on that too .
I must admit I was surprised it happened. I had previously sprayed some WD 40 on the catch probably last year somewhen. I regularly checked oil, water and topped up screen wash it always opened and closed normally.Not good, had it happen years ago on a customers old Renault Laguna. Hit 40mph and up she went. Luckily we got away with only a bonnet. What was very annoying was the fact I'd only done the rear wheel bearing and not been under the bonnet. Turns out the customer had been fiddling with the catch.
Anyway, out of curiosity is the bonnet safety catch seized?? That in theory is designed to stop this happening. Worth checking on this car and all future cars.
