I've 2018 4motion 150bhp I believe. The local mechanic has just done the timing belt and I asked him before he did it if he used the vw spec coolant etc. he say oh yes. so I went to pick it up today and he was just topping off the coolant. not with the vacuum I have to add, just by sitting it slightly uphill and running it till the fans kick in then topping it up. The coolant he says was G40 Coolant. G40. when id specifically asked him to use G13 0r12++. He said just top it up with tap water if it looks a little low. I said not distilled water? oh No he said just tap its fine. So I drove away thinking he must know best being a vw trained mechanic and all.
should I care what coolant is in this? Is it too late if it is the wrong kind? Do I have to flush the entire system to get the g40 out before I use g13 and how is that even possible?
looking for the G40 is fine replies....
F****** nightmare.
F****** nightmare.
