I have wired up a 7" stand alone monitor with front and rear facing cameras. I put a switch on each camera circuit so that I would be able to turn them on and off when I chose to.
However when I turned everything on, the cameras didnt turn on.
If I remove the switches from the circuits the cameras work fine.
So I'm wondering if the switches are causing too much of a voltage drop so that the cameras dont fire up?
If so, is there any switches that would work in this instance or any other suggestions on whats going on.
Or do I just remove the switches from the circuits and have the cameras on all the time when the ignitions on and just switch the monitor on/off when required.
Thanks.
Thanks.
