Trick I learnt with my inflatable tent which works with my Kela is before you try rolling it up lay down on the part folded tent/awning and do rolly pollys on it towards the open valves - you look a right prat but it works lol.Struggled a bit getting it small enough to pack away in its bag but I'm sure it'll get easier with practice
Thanks very much Colin, appreciated as a newbie to all this, can't wait to get the van out and on the road....You need a Kador strip and a set of figure of eight connectors. Fit the connectors onto the awnings and then slide the Kador strip between the rail on your van and the figure of eight
Great, thanks I'll be in touch shortly...As above, very simple to fit, and out up - The best on the market. We sell Vango if you want a price. Im sure we can look after you as a forum member ;-)
Cheers DavenjoVango sell a kit which includes the Kador Strip and Figure of 8 - you can get them for about £20 from the likes of Winfields - just make sure you order the right one as the Kador strip comes in a couple of sizes (in your case it sounds like you need the 6mm to 6mm - our Fiamma awning channel is only 4mm so we have the 4mm to 6mm).
We have the Kela III awning - so far we have only used it for one of our breaks, last October. Easy to put up and it worked very well - drive-aways very easy with the Kador strip and figure of 8. Our breaks since have been numerous but only for 2 or 3 nights at a time, as a consequence we have not been using (or needing). When we start longer breaks and/or sailing again in a couple of weeks we will start to use the awning again.
Tip for taking it down, you can do the role poly as above or use the deflate on your pump and it will suck all the air out for easy packing away.
Hi, I have the Vango Kella 3 low and want to fit to a Thule Omnistor wind out awning is there a specific fixing kit and can you supply?As above, very simple to fit, and out up - The best on the market. We sell Vango if you want a price. Im sure we can look after you as a forum member ;-)
Great , thanks. Phil@Phil Harris all you need is a kador strip (length of strong fabric with beading down each side) and some plastic figure of 8. Vango do sell as a kit for about £20, e.g. Vango Driveaway Fixing Kit - 3m Fiamma/Omnistor | Leisure Outlet
The only thing I'm not 100% on is the size of the channel below the Omnistor - I think it is 4mm (same as the Fiamma channels) which would mean the kit above (with its 4mm to 6mm bead) would work. If you look at people selling this 4mm to 6mm kit they do sell as compatible with Fiamma and Omnistor. I would ring them first to double check before ordering though.
That's what I do with my Karsten canvas tent - fold to width and then roll into bag.Dunno if this info is any use to those of you struggling with putting awnings away, but here goes...
As a boy scout I was taught to lay the tent bag out and fold up the tent to the length of the bag, so you know it will fit.
Then pop the bag over the rolled up tent, rather than try to stuff the tent roll into the bag. The same might apply to some of your awnings. Tis much easier that way.
Next weekend 1st trial. Have to let you knowThat's what I do with my Karsten canvas tent - fold to width and then roll into bag.
