THQ V2 with HID bulbs fitted today- not as tricky as I might have thought and even managed not to break anything.. first thoughts are it’s a big improvement, I haven’t driven at night but will take a couple of pictures when I do. I need to find someone with VCDS to get main and dipped on together but dab works fine and no bulb warning. Overall I think thq lights are pretty good as a unit, the fit was spot on. I tidied up the wiring a little but will just keep and eye on it. I bolted the ballast to the battery divider on the passengers side and doubled sided taped it on the drivers side- see pics. I also noticed the round plastic washer thing that came with the bulbs is a cutting template for the rubber cover which worked really well. Huge thanks to @dubber36 and @Mikem for blazing the trail on this one!
Looking good, let us know your thoughts when you try them at night?
