Tractor V’s T6 - Tractor 1-0 T6
James1000
Always good to see the farmers busy out harvesting at this time of year unless they are wider than you!!
Any idea what this is going to cost to fix ? Looks like some clips have gone on main unit.
Deaky
On yer bike
VCDS User
Moderator
T6 Legend
Around £12 for the lower casing and £25 for the upper ready to paint. Plus vat
James1000
@Deaky Ok thanks not too bad - glass? do you think those clips are available on the main unit or is that a replacement
Deaky
On yer bike
VCDS User
Moderator
T6 Legend
The bits with the screws in are part of the lower casing. Not sure on the glass
Skyliner33
VCDS User
T6 Legend
As Deaky said - it looks like upper and lower plastics, and the glass.
I have bought 3 painted upper plastics from this eBay seller (dont ask):
1963caymen on eBay
His work is spot on.
Pauly
VCDS User
Admin
Moderator
Aftermarket glass is pretty cheap but VW charge around £60 each !!
Can get your replacement and a spare for each side and plenty of change for that price
James1000
1963caymen on eBay
Hi - just wanted to pass on thanks for this it made it very easy. I ordered the replacement parts - the parts broken were part of mirror so that helped.
I now have a blind spot mirror which I guess is a bonus too
