Traction Control - ESC/ASR & HDA switch retrofit
Pin 4 in the abs module needs a momentary 12v to deactivate the ASR a rocker switch or simple push button works
switch part number7EO927134B WHS
switch connector8W0971636B
wires switch x 2000 979 009 EA
wires esp x 1000 979 038 EA
pin 6 is 12v i just run a wire with new connector as above to the switch and back into a joint for pin 6 to get power, you can run the wires through the drain for the A/C its easiest way its a pain to get the the abd module you need to remove battery and undo the fuel filter to get it out and up enough to get the cover off the connector budget a good few hours to do it properly you may need some coding to get the asr to turn off
Hi
Want to install TC switch on my T6 Euro6 LHD 2WD
Wondering if I can steal power / signal from start / stop switch except pin 5 TC button to pin 4 ABS module. Can anyone help with cabling?
TC Button Pin
1? 2? 3? 4? 5 to 4 on ABS. 6?
In the Connector the fields A2 to A5 should be empty. For your orientation: Pin 1 and 25 are red, Pin 13 on the other end is brown and Pin 38 is not connected.
just get soldering iron and gently remove some of the insulation from pin 6 thats KL15 12v get a twisted pair of wires and run them both to the switch in the dash the switch is a momentary switch so check with multimeter the connections basically then you have a pair of wires one with the new pin you click into T4 and one soldered to pin 6 12v if you have the OEM part number dash switch then it will have 4 pins, one is earth one is 12V for lights i never bother with, the other 2 connect when you press the button down you want those 2 it doesnt matter which way you wire those 2 together as its just creating a connection to aplly 12v to deactivate the esp
I Connector skal feltene A2 til A5 være tomme. For din orientering: Pinne 1 og 25 er røde, pinne 13 i den andre enden er brun og pinne 38 er ikke koblet til.
bare hent loddebolt og fjern forsiktig litt av isolasjonen fra pinne 6, dvs. KL15 12v, få et tvunnet par ledninger og kjør dem begge til bryteren i dashbordet. par ledninger en med den nye pinnen du klikker inn i T4 og en loddet til pinne 6 12v hvis du har OEM delenummer dash-bryter så vil den ha 4 pinner, en er jord en er 12V for lys jeg aldri bryr meg med, den andre 2 koble til når du trykker ned knappen du vil ha de 2 det spiller ingen rolle hvilken vei du kobler de 2 sammen, da det bare oppretter en tilkobling til aplly 12v for å deaktivere esp
Was probably a bit messy worded.
On the connector for ABS: pin4 and pin 6 to be connected.
Where should this be connected to the TC button?
And can I take 12v from another place than from pin 6 on ABS? For example from the start-stop button?
As I read from earlier in this thread, I can use pin4 from start-stop button to pin4 TC button instead of pulling cable to pin6 ABS connector.
So then I conclude that I connect pin4 from ABS connector to pin5 TC switch. Pin4 TC switch to pin4 start-stop switch. Is there more that needs to be connected in the TC switch?
Only -ve brown and +ve grey/blue for the switch illumination if required.
i really wouldn't mess with the stop start button you have to run a wire anyway from the modulator to the switch just use a twisted pair of wires and take 12v from pin 6
I have a t32 2017 no traction button but when me and some friends all got stuck in snow & ice on the drive while staying at an aibnb farm my van was the only one to make it out without a toe. I think it might be smarter than it looks.
Have connected according to this self-made drawing. Everything works except for the light in the button when it is activated. Is there anyone who can give a tip on how I can make the button light up?
Traction Control Switch has only illumination light inside. According to ERWIN wiring diagram there is no indication light.
Why do you want your switch to indicate it if you are getting this via Instrument Cluster dedicated LED?
On a side note, HDA switch has indication light built in but even if this is wired in it still doesn't work.
