I fitted the Westfalia under the van. There is a grommet behind the LH wiper scuttle plate that allows a connection to the 2 x 72 pin connectors under the steering wheel. There are too options that may or may not then route up under the passenger seat depending on rotary light switch type (for the main loom) . The main loom starts at te back of the battery box then down the fron bulkhead then mine goes straight back behind the heat shields and under a few plastic panels. Quite simple really although the instructions are unclear.
