Top Compartment Dash
Discussion in 'General VW T6 Chat' started by Gaz10, 13 Feb 2020 at 17:31.
  1. Gaz10
    Gaz10 New Member
    Hi all,
    Quick question regarding top compartment on my 2019 Highline Dash. It has that ugly looking hole with the 12v socket.
    I was wondering is the comfort dash lid and box compatible to replace it or is that a totally different dash needed ?
    cheers
  2. $immo
    $immo Built not Bought VIP Member T6 Guru
    There are a number of topics already on the area you are describing.
    Dash Top Thingy
    The search function is your friend. :thumbsup:
  3. Gaz10
    Gaz10 New Member
    Cheers for the response. Have delved into old topics but cant really find what i am after.
  4. Gaz10
    Gaz10 New Member
    I dug deeper on here and found the dash mod thread. Looking like a no go
  5. Wills
    Wills Senior Member VIP Member T6 Guru
    Van X have a speaker console currently available, which fits in the hole. There’s a cubbyhole version on the horizon, which has been delayed.
  6. DXX
    DXX Senior Member VIP Member T6 Guru
    hoggle and cgtmiles like this.
  7. Ayjay
    Ayjay Senior Member VIP Member T6 Pro
    DXX - Sorry for being thick but it’s still a bit early for me. Where is the original post that you quoted from please?
  8. Skyliner33
    Skyliner33 Senior Member VIP Member T6 Legend
    If you click the up arrow after where it says DXX said it will take you to the original post.
  9. Ayjay
    Cheers - didn't know about the 'up' arrow!
    DXX - I really would like to know where you got the parts for that hinged lid from (or did you make them all yourself before putting it all together?). It's exactly what I could do with for the same reasons as you! Can you give me more info please. Cheers in advance.
  10. DXX
    Plastic hinge and sheet bought on ebay. I made it with hand tools, not entirely straight forward as there is no square edge to use as a reference.
    I’m an apprentice trained fitter & turner so I have plenty of hand crafting experience with this sort of thing. It’s a bonus if your vice is close to the van, mine wasn’t!
    Give it a go, the materials are cheap and if you balls it up its a learning curve, start again.
    You will need to remove some material on the existing trim strip to create a straight edge for the hinge attachment, this has to be done before making the cover.
  11. Ayjay
    Thanks for the advice and encouragement but it's not going to happen! I'm pretty good with wood but, coming from a military background, I've spent most of my life destroying stuff and my limits on manufacturing / fabricating are usually dictateded by whether or not it can be stuck together with bodge tape. That said, my compliments on the job that you did - it looks top notch.
  12. Wills
    The Van X offering is approximately 4 - 6 weeks away from sale..
    Simon Carne likes this.
  13. Gaz10
    Gaz10 New Member
    That hinged cover is a great effort. Hats off man,i may have to try something like that if options are limited. Seen the speaker cover but was really after a flush fitting cover/ compartment.
    I will keep an eye out for this new van x offering to see what that looks like.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
