table behind the front passenger seat?
Discussion in 'Interiors, Seating, Lining' started by KombiKommando, 6 Dec 2017.
  1. KombiKommando
    KombiKommando Senior Member T6 Pro
    Map
    I seen a van with a small turn out table behind the front passenger seat (I've taken to becoming nosy at other vans in carparks..... ) it was a small table about the size of a dinner tray, (you know, the one your nan used to have on her lap....) looks like it was attached to the pillar next to the seat and designed to turn outwards as well.
    If I have made my ramblings clear, does anyone know where I can find this OR make it myself?
    Ta!
  2. Carlos Vandango
    Carlos Vandango Member T6 Pro
  3. KombiKommando
    Map
    definately not that! it was a small lap sized table, on a metal pole, which was attached to the pillar behind the passenger seat.
  4. Pauly
    Pauly Senior Member VCDS User Admin Moderator
    Map
    KombiKommando likes this.
  5. Leigh
    Leigh Senior Member VIP Member T6 Pro
    Map
  6. simon
    simon Senior Member VIP Member T6 Guru
    Map
    That looks great and easy to fit @Pauly re the kiravans table.
  7. drew_greenday
    drew_greenday Senior Member VIP Member T6 Guru
    Map
    yeah it will be simple to fit i reckon
  8. Leigh
    Map
    Just bolts / screws into the lower panel.
    Easy to move around to the required position & to remove altogether.
  9. KombiKommando
    Map
    Silly question but does it come with an actual table top?
  10. Leigh
    Map
    You'll need to get your converter / yourself to make a top.
    You can then have whatever shape, size, colour you want.
    Ours is the same as our unit tops.
  11. drew_greenday
    Map
    Looks like a rivet instead of bolts as that doesn’t need access to the rear of the panel. Easy enough though.
  12. Jietee
    Jietee Member
    Like the idea of this table. Can anyone recommend the best size and type of fixings required
  13. Leigh
    Map
    This is the type of Bracket.
    Mine looks like it's either bolted or screwed on.
    Definitely not rivited.
  14. Leigh
    Map
  15. Vinci
    Vinci Senior Member VIP Member T6 Guru
    Map
    image.jpeg G
  16. KombiKommando
    Map
  17. Hickey
    Hickey Member T6 Pro
    Map
    Just found these legs for £75 at chippy workshop they have some nice worktop too
    B Pillar Leg Set
  18. Tinman1UK
    Tinman1UK Member VIP Member
    Map
  19. Lord Mfwic
    Lord Mfwic Senior Member VIP Member T6 Guru
    Map
    We have this table. Its perfect and also swings out so you can use it outside the van when camping. Ours is screwed to the B pillar. Paid £75 for the leg with 2 brackets and modified an old table top I had knocking about in the loft. Tin of spray paint and good as new.
  20. slidepods
    slidepods Senior Member Trade Member T6 Guru
    Map
    If anyone wants a just a lightweight table top for a swan neck leg I have around 40/50 in stock. I am happy to do a special posted price for forum members just drop me a pm and I will get back to you asap
    DPS and Thogg like this.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
