T6 stereo wiring
RattyMcClelland
T6 Legend
I attempted to fit my Alpine X801d-u with the 801t5 plug and play kit.
Wasted 2 hours. It didn't plug and play at all. The internet lies.
What are these wires. I'm holding the alone wiring harness. Is misses a fair few cables.
The blue and green oem wiring blocks are completely missed. So is done of the beige. What are the 3 smaller bits. One must be dab.
I plugged the main plus in and nothing powered up.
I'm quite clued up on car audio add it's my hobbies but I'm stumped.
To top it off my airbag light is not on. No idea why.
rod_vw
Airbag always comes on if you have switched the ignition on with the dash warning light disconnected! That's the pitfall that all new owners have with these T5 & T6 dashboards.
You will need the aid of someone with VCDS or similar from this forum or a trip to the dealers to re-set it. If you are near me (see location map) drop me a PM and I can arrange to re-set it for you.
Rod
Absolut5
Trade Member
T6 Legend
The beige plug is the media (USB,) on the dash, the black one is the dab aerial, twin white is the twin FM aerials
Blue socket is for the OE microphone and green I think is for Aux
Did you plug in the black CanBus box into the supplied lead, as this sends the radio a 12v switch feed...
In order to retain the USB you will need a retention kit. And to use the dab black plug you also need a adapter, as well as the twin white ones...
Give us a call if you want more info
RattyMcClelland
T6 Legend
Lol. To fit the t5 kit into the t6 the dash had to be modified. So I melted parts and it now fits.
I managed to get the stereo to start up. Battery cable wasn't seating properly. Mfsw controls all work.
@Absolut5
I'll call tomorrow.
I'll need the dab adapter, FM aerial adapter ( this kit has no Aeriel provisions) and if a mic adapter exists.
Absolut5
Trade Member
T6 Legend
We have dab and FM but I'm afraid no microphone one is available, we can do a USB retention kit but requires the USB panel to be removed and taken apart
Absolut5
Trade Member
T6 Legend
You need a different harness...
Als0 do you have steering wheel audio controls ?
