Hi if anyone could help it would be much appreciated I am all out of ideas, I left my camper parked up on Monday after a 90 mile journey when i came back after approximately 2 hours it would not start. The key turns fine in the ignition but there is no term15 or term30 its as if the battery is flat but when i turn the key to attempt to start it the engine cranks and fires but as soon as I let go of the key it turns off.
I have checked all the feeds to and from the ignition switch and even tried a donor but the fault is still present, I have checked the term15 and term30 relays and all check out fine both where bench tested (coil and contact side). I have also tried to scan the vehicle with VCDS but it reports no faults or no comms due to no ignition feed.
I Have checked all the main fuses under the battery and all the fuses in the cabin fuse box and all check out fine. I have got as far as I can without the relevant wiring diagrams and knowledge of the T6 so I am asking for some well needed advice please LOL. Does the T6 have a general body control unit?
