AbsoluT5 carpet lining
@Absolut5 nicely finished, something I will be getting done once I’ve sourced a vehicle. What does the 3 layer insulation system comprise of?
Dynamat/Skinz with full coverage of the rear ceiling, sliding door/s, tailgate/barn door, rear quarters
Closed cell applied on top of the above
Then 30mm insulation
The last couple T6s we have had in we’re both with Kombie bulkheads
Both feature our 3 stage sound proofing
2 tone carpet lining, again seamless around the rear opening
Complete hidden fixings Dense panel set with recesses around handles, lights and on sliding door
Cabin matching ceiling trim, Oe looking, light inside and less claustrophobic
Various sockets, flush fit speakers in the ceiling were added
One of them had our Signature Audio based around our own design and manufactured underseat sub enclosure with JL Audio sub, amp and Hertz components in the front, the other had the Eton 8” door and pillar upgrade
And a Pendle Performance remap on the Sportline 204
Our services -
Carpet and vinyl lining
Kombie conversions
Window installation
Webasto heaters
Audio, plug and play setups
Pendle Performance Agent
Cruise control
Full electrics inc solar
B14 and VanSlams
Home of the original underseat sub enclosures for the T4,5
and 6 NOW A ACTIVE VERSION IS AVAILABLE...
Www.Absolut5.co.uk
01980 624740
One very happy lady customer picked up her Transporter yesterday
Anthracite carpet, again seamless around the rear opening
Remote mood lighting
Leisure battery and mains hook up
Various sockets installed to customers requirements
Rear speakers flush mounted in the rear being powered by the Kenwood DMX 7017dab
And carpet Loc8 table panel
Our services -
Kombie conversions
Window installation
Webasto heaters
Cruise control
B14 and VanSlams
Www.Absolut5.co.uk
01980 624740
Just love adding colour into the mix
Especially when it’s black and anthracite carpet
This red T6 long wheel base was unhappy with the previous work that was done, so we stripped it down and did the following-
Black and Anthracite carper, no joins around the tailgate opening,
6mm dense panel set with complete hidden fixings, no screws or clips hidden under the carpet, recesses around handles etc
Cabin matching ceiling trim keeps it Oe looking and keeps it looking light inside
6 cool white light with on/off/door switch, various sockets were added
Rear speakers
And some matching red vinyl panels added to finish the looks
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
B14 and Vanslam suspension
Kombie conversions
Cruise control
Audio inc plug and play headunits and speakers
The home of the original underseat sub enclosure for the T4,5 and 6 NOW available as a active setup
Www.Absolut5.co.uk
01980 624740
CCBA44B7-A9C2-400C-B886-032FE7284438.jpeg EFC0FC7E-AEFC-4B40-A129-0786F2637042.jpeg 875E78E0-03D5-4868-976A-1A2482EEADEF.jpeg
New T6 came for our 3 stage sound proofing, black and anthracite carpet lining, the black makes the blue vinyl seat belt panels pop out....
Remote mood lighting which we now do not just along the sides but along the back to, which makes it look much nicer.
As with all out lining installs attention to detail is high on our list, seamless around the tailgate opening, none of the horrible cuts/joins or folds, recessed switches and handles and recesses on the sliding door to break up a normal flat panel.
This T6 also had our Signature Audio setup installed, based around the the factory headunit, using Hertz and JL Audio products, this one had a twin seat, so we dropped out sub enclosure under the middle compartment, the owner was stunned by the improvement
Finished off with Vanslam coilovers and chrome side bars.
Pm or call us for a quote
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
Kombie conversions
Cruise control
Www.Absolut5.co.uk
01980 624740
Really nice @Absolut5,do you have any tips for capeting the loc8 table panel? We have just fitted one and would like to carpet it to match,those ones you have done look really neat,thanks very much
Thankyou
Degrease the plastic
Use megavanmats carpet,
Glue both surfaces
Lay the carpet really loosely where the table sits in, if it’s to tight there won’t be enough stretch for the tight bits. work it into the corners first
The flat surface is done last
Haven’t posted for a while but been so busy.
We did one of our favourite colour combinations this week
Black and anthracite carpet with red vinyl seal belt panels, along with cabin matching ceiling trim for the Oe look and males it look less claustrophobic
3 stage sound proofing was installed first
Carpet was applied with no joins on show around the tailgate opening
6mm dense panel set with complete hidden fixings, no nasty clips or screws on show. And recesses around the handles etc
We also added led lights with on/off/door switch. Rear speakers and a AGM leisure battery and Ctek charger
The other one in the pictures is a cracking looking yellow T6 with a Abt kit, this was his work van so incorporated a box to hold his straight edges for brick laying.
Again 3 stage sound proofing
2 tone carpet lining including lining the back of the Kombi bulkhead,
Led lighting
Rear speakers mounting flush in the ceiling, much nicer looking than pods
Full signature audio was installed to finish it off.
Www.Absolut5.co.uk
01980 624740
Stunning looking T6 left us this week with the following installation completed
Anthracite and smoke carpet, no joins around the tailgate opening,
4 cool white light with on/off/door switch, various sockets were added
Rear speakers
Full Signature Audio setup using JL Audio and Hertz products
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
Kombie conversions
Cruise control
Www.Absolut5.co.uk
When we sound deadening the arches we remove the wheels and liners and do it from the out side... this leaves the arches clean and sharp looking
I’m looking to externally deaden the front wheel arches and possibly the rears as well.
Any comparisons or opinions on the two products I have in mind are very welcome. Efficiency, reliability, weight and cost (in that order) being the main factors.
Silentcoat 4mm OR Dynamat Xtreme???
If you are doing the outside then it’s Dynamt all day long, it sticks so much better than Silent coat, which tends to come unstuck
Silent coat is thicker but you don’t want to trap moisture behind when it comes off
Reactions: DXX
2B0A51DB-C5C9-4ADA-BB9C-01AD6820C4D9.jpeg 987708FA-ECD3-4DEE-BB8E-9DAAD5D68CE9.jpeg C171E45A-3992-4AC3-8031-317DFE54BC8D.jpeg 582117E5-08BF-4D98-8A2A-376F07CFA617.jpeg 75EBDDE8-CD1E-4021-9E98-15B4ACACCAE3.jpeg E41E654B-AECB-48BF-912D-D08C6634147C.jpeg CCED5F99-C7EB-4428-AA2B-1D6130EBC045.jpeg FAABA0E6-CF81-41C8-8C66-F861F52594D7.jpeg 7E87407E-40D6-47F8-A391-43EAA21420D3.jpeg 4E4905B0-5EF6-46B1-AE20-0E2E160749BB.jpeg 8B8A9D4B-9B32-4459-AFD4-8E9FE9C949AF.jpeg 294BF69E-04BD-47F1-B480-4249406B1E5B.jpeg B4D40472-44F3-47B8-9729-54C7859FBA24.jpeg
A collection of Pictures of some of the work that left us this week
A stunning Bamboo green had the following-
Anthracite carpet applied to the metalwork
Panel set with complete hidden fixings
Grey and Azure vinyl for the individual look
Mains hook up/leisure battery and sockets installed to customer requirements
Webasto diesel heater using the factory trims for the Oe look
Kenwood DNX 9190dab headunit, with parking sensor/mfd/mfsw and factory camera integration, Kenwood dash camera
Finished of with a remap using Pendle Performance software
The Orange T5 came in looking sorry for itself, it had previously been done by a previous company to a very low standard with sub standard electrics, no fusing, 3 core lamp cable being used for cabling and it was earthed via a self taper into the bed upright!
We stripped it all out and applied the following-
3stage sound proofing
Panel set with complete hidden fixings and recesses around handles etc, side storage was added
Cabin matching ceiling trim along with a new cab ceiling trim to keep it light inside
Ply floor with Altro was fitted with added attention to detail than most apply by taking time to cut it perfectly, we hate seeing it cut short and to long so it sticks up
Full electrics
Signature audio with rear speakers
Kenwood DMX 7017dab, Kenwood dash camera, shark fin aerial. And Pioneer reverse camera
Webasto diesel heater with 7 day timer
Genuine cruise control
What a transformation ! And great to see the customer back in love with his van
Would like to say a Big thanks to the team.....
Our services -
Kombie conversions
Window installation
Webasto heaters
Cruise control
B14 and VanSlams
and 6
Absolut5 Audio ltd
Www.Absolut5.co.uk
01980 624740
The owner of this T6 left with a big grin after our sound proofing/insulation/carpet lining package plus our Signature audio
our services-
Kombie conversions
Window installation
Webasto heaters
Cruise control
B14 and VanSlams
and 6
Www.Absolut5.co.uk
01980 624740
Another one left today with our lining package-
3 stage sound proofing and insulation
2 tone carpet lining, seamless around the tailgate opening, no joins here
6mm dense panel set with complete hidden fixings, no screws or clips under the carpet
Oe looking ceiling
4 x led lights in ceiling plus 2 in tailgate
Pair of Kenwood speakers in the rear quarters
And a privacy tailgate window finished it of
Pm or call for a quote
01980 624740
Www.Absolut5.co.uk
7F16F36E-754B-4C65-9188-31E9755609EF.jpeg 99F27DCB-0B2E-4E68-8960-0D3B197E22F0.jpeg 9D4E34B4-931E-4D37-89EC-C6B3F9C7491D.jpeg 6EC7B521-EC5D-43D9-B229-4A489D376B56.jpeg FE5615C2-A193-4B4D-B806-78E027FC0C2E.jpeg EEA26E8E-3987-4F6F-A2C9-F4E4328E8A40.jpeg 20C1763A-E24F-40B0-899C-8D4040EF8578.jpeg
A few pictures of some T6s we have carpet lined,
2 tone being the most popular and featuring our panels that have no fixings on show, cannot be seen even under the carpet surface.
Oe looking ceiling trim to keep it light inside and less claustrophobic
Various sockets, lights and speakers installed to customers requirements
Pm or call us on 01980 624740
Www.Absolut5.co.uk
Brand new T6 came in for our-
2 tone carpet lining, seamless around tailgate opening, no joins on show
Dense panel set with complete hidden fixings, no screws, or clips under the carpet, recesses around handles etc for extra detail
Led lighting in load area controlled by a on/off/door switch and 2 in the tailgate, which come on when you open it
AGM leisure battery controlled by a Ctek D250se and various sockets
Full signature audio was installed, inc rear speakers
Black side bars to finish it of
Our services-
Carpet and Vinyl lining
Window installation
Kombie installs
Webasto heaters
Audio and suppliers of plug and play
Cruise control
Full electrics
B14 coilovers
Westfalia Towbars
The home of the original T4/5 and 6 underseat sub enclosures
Call or pm us with your requirements
Www.Absolut5.co.uk
01980 624740
