T6.1 Highline Aerial Connector
denz1968
I have just dismantled the dash to remove the head unit to install a DAB aerial from ali express as per a previous thread.
I got the Fakra Z version new aerial but the connector is different to the factory fitted aerial. Is there an adaptor someone can recommend so I can connect the Fakra Z into the head unit please
I have photos if needed
Many thanks
OK photos added for clarity
Help would be appreciated
OEM Headunit
OEM Connector
Connector on DAB Aerial purchased
Yes radio keys, but you may find the cables won’t be long enough to pull it out far enough to get to the plugs. If this happens you need to the centre console.
