T6.1 fog lights
darylfrench
Have any one manage to find the pin out for the light swith to use front fog lights on a trendline 2020 T6.1
Got fog lights and wiring loom and switch wire but can not find a aftermarket switch yet as so new.
I tried the Philips LED fog lamps but I found the light output was negligible. They looked better though, but I ended up putting Nightbreaker H11 in them, the only incandescents in the front but LEDs just didn't work well.
Thanks for your help my van is a t6.1 and thing are a little diferant.
Where can I get some cables from to go into bcm
Hi @darylfrench, did you manage to get your fogs working? I’m looking to retro fit a set to my T6.1 but struggling to find any kits or much info.
I’d love to hear where you sourced your bits and any info. if you had success. Thanks.
Thanks @darylfrench, I’ve only just checked back and seen your response. I’m just waiting on fogs and loom to be delivered and I’ll be giving it a go:thumbsup:
I don’t suppose you made a note of the pins? Also did you already have power from the fuse box to the relevant pin at the bcm? Cheers
