T6.1 electrical fault
kirkm5238
Hi can any one help with this problem it’s my cousins van done it a few times now when codes r read they is loads a lot of them some said communication error between modules but need to get it full scan with vcds I haven’t read codes this time round this is a video of the problem open and shut bonnet van starts thanks
Hi robbert it says parking heater on the list of modules but it doesn’t have one I take it that’s a diesel heater thanks
Any history of recent modifications, work, adjustments?
Hi robbert yes it’s had a towing electrics put on witch was a genuine kit from TPs and factory led lights fitted with a kuftec loom I did wonder about the connection to the gateway module behind the clocks
Who did these modifications?
Have you got orginal VCDS AUTOSCAN(block map) before any adjustments/modifications?
I went down to my cousins tonight sat in van with it ticking over I herd something click now and again behind dash and then van starts to play up l
Hi
a local Garrage did the coding for tow bar loom they got the coding of vw or Odis can’t remember but they coded it wrong the tow bar electrics would not work van went to vw they said it was installed incorrectly but when I posted a copy of coding on here it was coded for a different country so another member gave us a different coding and it all worked as it should
