Hello!
I have a 2013 Caravelle T5. On the roof in the back of the car the control panel for heat/ac have is not lightning up anymore. No air is coming out of the vents, even if I on the control panel in the front push "rear" and turn the fan all the way up. Took out the panel and I did see some corrotion on the plug and print board. Maybe just a easy swap to a new one?
I have now got a "new" used display from a similar car that the seller said was working. Put when plugged in nothing lights up. If I measure on terminal 20 and 19 I get 12 volt when ignition turned on and 14 volt while running. Pretty sure its getting is getting it power, but no light or air is coming ut of the vents in the rear no matther what I am doing.
So where to look next?
1. The pins on the used new unit looks good 2. Pins on the used one looks corroded/shortcut
3. Some corroded pins on the female plug. I have cleaned them 4.
