Suspension - Kent
csnell71
I'm trying to find someone who has stock of
Bilstein B14 for a T6 T32 that would be able to fit on or around the 18th march and is located in the Kent area.
thanks.
Wouldn’t personally do B14’s these days, I have them and they are quite harsh. Mine are 4 years old and have been brilliant, but the suspension game has moved on a bit over the years.
Contact Bognor Motors, take a drive down, go for a spin in one of the demo vans and take your choice, they’ll fit while you wait.
Interesting, only slight glitch is I'm in France atm and so I need to decide before going to get them fitted, and I need it done week beginning march 15 before my mot.
I have a 205 kombi on 18s never loaded up much. I like a sporty ride. I want it lower than stock but not on deck.
So any recommendations most welcome.
STX would be a good choice, you won’t be unhappy with them and they are reasonably priced. I’m going to get a set shortly to replace my B14’s. Bognor will do a drive in/out for you.
We can certainly help. With supply and the dates.
I would recommend the B14 Komforts if you want to stay with Bilstein. Or STX (by KW) is a great option and cheaper too.
Happy for a chat in the phone to run through options with you.
Hi, Can anyone recommend Mechanic or garage in the southeast/kent to lower my T6 I've just racked it out for work it looks uneven with
the back lower than the front .
Would like it lower about 30mm at the back and about 60mm at the front I've got no idea where to start I wanted a vw expert to recommend
what best to go for best.
any help would be appreciated .
Loads of well respected suspension specialists on here take a look thru threads
Hello mate.
Im not far from you and I know your pain, local specialist are hard to find however I can't recommend @BognorMotors and @The Van Cave highly enough.
I do also know of a VW/Audi Specialist called Youngs Garage in Gasoline ally Wrotham, I've heard some really good reports about them and they have a couple of transporters there at the moment, might be worth a google and chat.
Im sure Chris @The Van Cave can advise on whats best and supply the parts for them to be fitted locally.
CRS Performance looks favourite but it’s a bit of a drive about 4hrs
Hello mate.
Thanks for the recommendations . I think it will be worth the drive to get a specialist Hopefully get it how I want it .
That sounds good idea, I was thinking of going down night before and staying over night . How long does it take them to change over suspension
not much more than an hour or so I believe but I think Steve now does alignment aswell so an all in one package whilst your there
I could be wrong, a few hours. Did you have a particular suspension setup in mind
I’ve got no idea I know I need the front Lower more then the back to even it out . Only about 60-70 mm lower maybe .
I’m sure you’re right with about an hour @dandan88
@Shifty101 if you get in touch with Steve @CRS Performance to discuss what you want, Steve can offer his specialist advice and then be fully prepared on the day of your appointment, so it won’t take long…. they’re very efficient at swapping out suspension setup’s. :thumbsup:
