Stripped bolt head in roof rails - help
Richm
After discovering a leak I’ve been trying to remove the roof rails today and found that one of the bolt heads rusted and stripped.
I can’t get pliers in to grab it and I don’t really want to be hammering down on it in case I damage the van.
Any suggestions on how to remove it?
Is it loose or fixed in place? If it’s loose a pair of long nose pliers.... if it’s fixed you might have to drill it out?
It’s fixed.
if I need to drill it out, that will be tomorrow’s job. After watching plenty of you tube videos!
They are clipped into a spring steel bracket that you can see with the headlining removed…
Maybe possible to remove it from the inside depending on the length sheared off.
What a ridiculous design anyway, that allows water ingress into the interior of the van! What were VW thinking that day!? :mad:
Nope! My key is sewn into my pocket too on a very long string! I also lick the windows on the sunshine bus
I bet you also have a long piece of string on your gloves that goes up your sleeves and over shoulders ;)
Yep! Doesn’t everyone?!! But, I bet you don’t have an “R” and an “L” on your wellies like I have!!!
