Hi all, is there a way of stopping the alarm going off when I am sleeping in my combi. I know there is a switch on the b pillar that I believe is meant to stop it but as soon as I move it triggers?? Any pointers as to where i am going wrong??
Open your drivers door, press the switch, close the door then lock. Or a better option is to manually push the buttons down from inside the van, that way you're not putting any alarm on at all.
Or just use the manual door lock switch on the top of the drivers door. This locks the doors but does not set the interior monitoring alarm.
Yup this is what we do, just remember that to open the sliding door from inside you need to do a double pull on the handle.
I set the perimeter alarm when in the middle of nowhere but just use the internal button if I'm on a campsite.
We don’t bother locking the doors when in the van on well occupied UK campsites - thinking being that we have camped in tents for years with nothing but zips and canvas between us and anyone wanting to get at us without problem and/or hearing of someone else having problems on sites. Obviously, if wild camping or on sites with few other people around we might think a bit differently.
I think by trial and error, we discovered that pushing the lock button TWICE on the key fob seems to lock the van but disable the alarm. But like others, we don't lock it on a campsite - only when wild.
You can risk locking yourself out with this method. we use the lock/unlock button on the inside of the driver's door when sleeping.
So what does this mean? Everything's still locked but dead locks aren't active? How secure is it without the dead locks?
If the van is deadlocked or “safelock” active. You can’t open the doors from the inside even with the handles. A second press of the remote disables the deadlocking so the doors are locked but you can open the van from the inside.
So am I missing something here then? Is a double key fob press to lock when inside not a good thing? Then the deadlocks are disabled and you can still open the doors from inside the van?
I think the slight inconvenience with "double-clicking" is that the alarm sets off then when a door is opened . However, the interior monitoring is disabled. Have a look here ---> Vcds For Begineer
That is why I find it easier (as stated above) to use the manual door lock switch on the top of the drivers door. This locks the doors but does not set the interior monitoring alarm. You don't get the noisy double locking and you can still open from the inside without an alarm going off. You just need to pull the sliding door handle twice to get out and can push the knob back down again when you get back in.
Switching an inside light on would also set off the alarm as would opening a door, even when double pressed. Just use the interior door switch as already said.
