Spot lights fault
ma77y
Hello, I have installed 3 spotlights in the van on the sliding door side, it's run through a fuse box and into a CBE dimmer switch. Now here's the issue.....
I put the fuse in and the lights come on but very dim (dimmer switch is off) turn the dimmer on and the lights come on as expected and the dimmer works too. Switch the dimmer back off and they go very dim again.
Now when I remove the fuse for the lights they go off, but what I've also noticed is that when I take out another fuse in the system for the usbs the lights go off. I've removed both fuses and checked continuity between the two wires and there is no continuity.
I'm stumped as to what I've done wrong there don't appear to be any shorts as the fuses don't blow.
Anyone any ideas?
