sponge / foam surround for loom - where from?
Skyliner33
VCDS User
T6 Legend
I am looking for some insulation like in this pic as the wires to the ceiling lights in my ply roof (that I taped down) seem to have come loose and I can now hear them bouncing on the ply roof. I was hoping to find some of the sponge tubing in the pic will stop this even if the wires are not fixed to the ply.
Screenshot 2020-05-13 at 10.27.59.png @Dellmassive hope you dont mind me using the pic.
its classed as Upholstery Foam "sheet" . . .
have a look at the 1.27cm 1/2inch example here :
more modern foams are EVA or closed cell (dont absorb water), which is great for sticking on the van for sound proofing etc . . . but this stuff, the upholstery stuff is more oldskool.
This is the stuff to use. Thin enough self adhesive foam tape, 3mm thick, 50mm wide, to fold over a loom. Very sticky. Used by A/C engineers to join the foam pipe insulation;
Armaflex Pipe Insulation Tape, 15m x 3mm x 50mm L414
Available from Amazon.
Thanks, is that sticky on both sides?
When looking at that on AMazon I also noticed this:
