Mine was removed yesterday in 15mins with a hammer, 2 centre punchs, needle nose pliers and a wrench. Fortunately this was intentional as I was fitting an lpg tank with a mate and inexplicably didn't have the locking nut. He took one look and said I'll get that off. Bit of a fight and it's not even damaged.
So make sure it's as tight as you can humanly get it and the little nipple that stops the shroud being turned is absolutely flush. Not even a gap of a mm. Still can be removed but a fair bit harder. My shroud moved about 1mm which made undoing the bolt with needle nose pliers and a wrench a bit of a fight but fairly trivial.
Si
Si
