Portable Power Packs - LifePo4 Battery Boxes -- How I done It --
ECOFLOW DELTA 2
ITS coming.
And now with Lifepo4 cells.
Its finally here --
The ECOFLOW DELTA i always wanted.
  • Quick Look
  • Total Outlets15
    Mobile App
    Net weight (lbs)27lbs
    X-Boost Output2200W
    Net Weight (kg)12kg
    Capacity1024Wh
    AC Output1800W total (surge 2700W)
    Dimension (cm)40 x 21.1 x 28.1cm
    Solar Charging Input11-60V, 15A, 500W max
  • Capacity
  • Capacity1024Wh
  • Extra Battery
  • Extra Battery
  • Output
  • Total Outlets15
    X-Boost Output2200W
    Car Power Output12.6V 10A, 126W Max
    USB-C Output100W
    Number of USB-A Output2
    DC 5521 Output12.6V, 3A
    Number of USB-C Output2
    USB-A Fast Charge18W
    USB-A Output12W
    Number of USB-A Fast Charge2
    Number of AC Outlets6
  • Input
  • Car Charging12V/24V, 8A
    AC Charging1200W
    Solar Charging Input11-60V 15A Max, 500W Max
  • Battery
  • Cycle life3000 cycles to 80%+ capacity
    Battery ChemistryLFP
  • General
  • Mobile App
    Bluetooth
    Wi-Fi
    Net Weight (kg)12kg
    Dimension (inch)15.7 x 8.3 x 11.1in
  • Supported Battery
  • EcoFlow DELTA Max Extra Battery
  • Environmental Operating Temperature
  • Discharge Temperature (F)14°F ~ 113°F
    Discharge Temperature (C)-10°C ~ 45°C
    Storage Temperature (F)14°F ~ 113°F (optimal: 68°F ~ 86°F)
    Storage Temperature (C)-10°C ~ 45°C (optimal: 20°C ~ 30°C)
    Charge Temperature (F)32°F ~ 113°F
    Charge Temperature (C)0°C ~ 45°C
    Operating Temperature (F)68°F ~ 86°F
    Operating Temperature (C)20°C ~ 30°C
  • What's in the box
  • What's in the box1.DELTA 2 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 Cable 5.User Manual & Warranty Card
1662621884641.png1662621899430.png1662621913182.png1662621923263.png1662621940249.png1662621953154.png
Its finally here --
  • Quick Look
  • Total Outlets15
    Mobile App
    X-Boost Output2200W
    Net Weight (kg)12kg
    Capacity1024Wh
  • Capacity
  • Capacity1024Wh
  • Extra Battery
  • Extra Battery
  • Output
  • Total Outlets15
    X-Boost Output2200W
    USB-C Output100W
    USB-A Output12W
  • Input
    AC Charging1200W
  • Battery
  • General
  • Mobile App
    Bluetooth
    Wi-Fi
    Net Weight (kg)12kg
  • Supported Battery
  • What's in the box
View attachment 171631View attachment 171632View attachment 171633View attachment 171634View attachment 171635View attachment 171636
Wow 1200w AC charging. That’ll be good.
Impressive spec. The new Jackery missed a trick I think. No app connectivity. This has it all and is priced similar to the Jackery £1149
its in peeps. . . . I've just ordered mine (20mins after being announced)
so excited :mexican wave:
EcoFlow DELTA 2 Portable Power Station​
plus with a free outdoor cover (limited time WSL !!) . . .
that bag look awesome . . . . no one else is offering bags of this quality and useful ness. . .
once again ECOFLOW shows that they are the top of the game . . .
The wait is over. DELTA 2 is open to order today. Buy yours before September 23rd & we’ll throw in a waterproof bag for outdoor
use. Shop while stocks last!​
1663339373154.png+++
well Busfest-22 is over. . .
The Anker 757 + Ecoflow River Pro didn't disappoint. . .
we had these backed up with a @Dellmassive battery Box
and a 200w Renogy suitcase solar - via a victron mppt.
this run the twin compressor fridges. . . plus USB charge stuff. . .
plus charging a few ppls phones and tablets etc . . .
it also run the EHU feed for the Disco tent and our main tent lighting. . . .
in all some great OFF GRID living.
nice . . .
Hi Lee, we're looking at the Ecoflow Delta 2 as well but there is no sign on the website of a free cover if you purchase one - did you pre-register ?
yes. . . i added my email address for new info and products etc. . .
they sent me two emails today . . just saying the below. . .
but there wasnt a code or anything . . .
just this email link: ( so im hoping that people who ordered via that link will be offered the bag? ( i have the same email from the USA based ECOFLOW detailing the same offer)
link below.
BUY DELTA 2
@Dellmassive thoughts on the Delta 2, CFX3 fridge plus solar panel as long term year round solution for power in a garage?
Sounds like a winning combo.
But it will depend on how much solar you connect to it over the darker winter periods.
And what your loads are...eg fridge plus whatever.
You could build a cheaper version?
Maybe a couple of AGM leisure battery's, with solar controller, 200-400w worth solar panels and run the fridge from 12v?
That way doing away with the inverter aspect.?
Or did you plan on using other mains powered kit?
I run a solar shed/garage .....
Have a look
That thread was the inspiration for a new setup!
I quite like the portable aspect of the Delta 2 for camping - could just unplug the solar panel and use elsewhere - and use the power pack as a backup for power cuts...
@Dellmassive I'm wanting to order a Delta2 but can't decide whether to do it on their own UK site or via Amazon UK.
Which site would you recommend ordering from & why?
TIA
Mike
TIA
Mike
you can do either. .
EcoFlow hold stock in the UK via Amazon or a Dropship holding warehouse.
i have bought from both methods . . .
both have been very quick when the item is stocked, and both have been shipped from within the UK,
my personal option is to go via Amazon UK as the aftersales support is awesome. . .
i got my EF Delt2 direct from EF but it was delivered without the carry bag/case . . . im still waiting for a reply from them.
check it out :
other option . .
check it out :
other option . .
@Dellmassive Great Thx 4 the info.
I was leaning towards an Amazon order for independent CS :thumbsup:
Amazon CS is one of the best I've come across . .
they always resolve an issue, via return/refund/replacement.
I've not had one problem with them yet - in years.
Dealing with Companies direct however - the jury is out on that one . . . . .
especially Chinese based companies claiming to be UK based - , ie Renogy, Bluetti, EcoFlow, Anker, etc etc etc ( all the modern tech comes from china anyway)
some are better than others . . . but Amazon will always address any concern.
here is our EcoFlow Delta-2
heres a few pics for now. . .
that was the delivery day . . .
next up some close ups . . .
size wise. . . .
this is the stack . . .
this is the Anker 521, Ecoflow 650 and the Delta2 . .
first use. . .
charging the Diag Tablet for a FW upgrade. . .
now for the APP....
settings tab . .
ECOFLOW RIVER 2 series . .
RIVER 2 Series Spec Table​
The entire RIVER 2 range now uses LFP battery chemistry. So it not only lasts for years, but there’s next to no maintenance compared to a gas generator.
Not only that, but we’re offering all RIVER 2 Series customers a 5-year warranty, one of the longest in the industry.
So how does RIVER weigh up against its second-gen rival?
With LFP chemistry, you now get 3000+ battery cycles, compared with the 500 you get with NCM. RIVER 2 has a 6x longer life than the average power station, lasting for around 10 years, even if you use it every day.
With LFP, RIVER 2 is now 30% lighter than the previous generation. At only 7.7lb, that’s the same weight as a steam iron or a bagless vacuum cleaner.
Now here’s what you’ve been waiting for. 38% faster charging than RIVER, RIVER 2 can fully charge in only an hour. Fancy a last-minute camping trip? RIVER 2 can be fully charged by the time you’ve packed your gear.
GRAB YOUR GEAR ON OCTOBER 25.​
