Portable Power Packs - LifePo4 Battery Boxes -- How I done It --
* New Product *
ALLPOWERS Monster X 2000W Portable Power Station, 1500Wh Power Generator
1500wh @ £1400 is £0.93 per wh
About this item​
  • 【Power for Any Range of Electric Vehicles】ALLPOWERS Monster X 2000W Portable Power Station could work as an emergency backup battery while power used up, fully-charged for 1 hour could help electric vehicles last for 15KM(Power Generator was 100% fully charged)
  • 【Charge 11 Devices Simultaneously】:ALLPOWERS portable power station is equipped with a 1500wh lithium-ion battery pack. Solar generator features 4* AC outlets (PURE SINE WAVE, 2000W, peak 3300w), 2* Type-C ports, 4* USB ports, 1* car socket. Solar generator can charge your 11 devices at the same time.
  • 【3 Recharging Methods】: ALLPOWERS solar generator supports to be recharged by 3 outlets simultaneously and only needs 2.5 hours! (DC5521 or Anderson+Type-c+AC wall outlet). The portable power battery supply only needs 4 hours to get fully charge by AC wall outlet; 6 hours under direct sun light with solar panel (DC5521 or Anderson); 24 hours by Type-C in right.
  • 【Widely Range of Application】: With a higher 2000 wattage, portable power station is designed for home emergency, outdoors, home, travel, camping, road trips and so on. Allpowers solar generator supports charge Personal electric devices, TV, Fridge, Coffee machine, Microwave oven, CPAP, Drill, Saw, Blender, Hair dryer, and more.
  • 【Phone Remote Control】:ALLPOWERS portable power station supports wireless connection via bluetooth with ALLPOWERS APP (supports iOS 9.0 or above /Android 4.3 or above). Power generator bluetooth technology provides a stable and advanced experience to remote control the solar generator almost anywhere.
  • 【What You Can Get】: 1*Allpowers portable power station (1500Wh solar generator), 1*AC Adapter, 1* user guide. 18-month product warranty with 24*7 friendly customer service of Allpowers Power generator. If you have any problems during use, please contact us, our service team will be available at any time.
* New Product *
just bagged myself one - £40 off offer atm !!!!
296wh @ £205 is £0.69 per wh !!!
Enginstar 296Wh/ 80000mAh Portable Power Station 350W Pure Sine Wave Solar Generator with Wireless charging, USB-C, AC/DC Outlet, Built-in LED Flashlight, for Camping, CPAP, Emergency​
About this item​
  • PORTABLE & EFFICIENT POWER SUPPLIER: With the fold-able handle design, it’s easy to carry the power station with you. 296Wh/ 80000mAh capacity is ideal to power your devices by AC/ DC as well as the 10W wireless charger, suitable for mobile phone, laptop, CPAP, Mini refrigerator, etc.
  • EASILY CHARGED BY 3 WAYS: Not only can you the power station by AC input or car charger, with the built-in MPPT controller, you can also charge it by panel solar efficiently. Wherever you are, the Enginstar power station will always be your company.
  • PURE SIN WAVE KEEP YOUR DEVICES SAFE: With 10-year experience in fabricating lithium-ion battery products, ENGINSTAR Pure sin wave power station can protect your sensitive devices and offer you a better solution to your power supply problem during travel, camping and emergency situation.
  • SAFETY IS THE FIRST: Under the protection of the Battery Management System (BMS), the battery state is monitored, and free of problems like over discharged, over discharge or over temperature. You can use the Enginstar power station with relief.
  • PACKAGE INCLUDES & CUSTOMER SERVICE: You will receive 1*Enginstar R350 Power Station, 1*AC Adapter, 1* User manual. We offer 7*24 rapid customer service, 30 days money back guarantee, 24 months warranty, life time technical support.
  • The continuous output power is 350 Watts max. Please check the rate power of your device before using. If connected with devices that over 350W, this power supply will shut off and turn into protection mode
  • When the AC button is pressed, the red triangle light will come on, this is the automatic AC output detection function that comes with the energy storage power supply. Please do not worry, this is normal. When the automatic detection is complete the red light will go out.
UK version shown :
Irritatingly, mine arrived today and shows no AC output with the inverter in use.
Is that just mine being faulty or have others that have this experienced the same issue?
@Samro - which unit?
The latest one, the Enginstar shows the AC ON and Watts drawn. (when you press the AC on/off)
On with AC off :
the ON with AC on, no loads :
now all ON and pulling 264W from AC via a air pump blower.
and finally all OFF except AC ON and running air pump.
Enginstar storage and carry bag.
thank you @Jollyvan for the heads up
Here we have the purpose built bag for the Enginstar power bank, but will work for similar sized units.
Here is mine,
its nicely padded for protection, with two large handles and a removable shoulder strap.
the unit sits at the bottom . . . . there is a internal flap below the lid than protects the unit from the PSU an plug that you can store at the top of the bag,
there is also a pocket at the top of the lid that worked well to store the extra leads,
12v car charger lead,
MC4 solar input lead,
instruction booklet,
all zipped up and ready to go,
im not keen on shoulder straps so ill leave that off for now.
it seems a good bag that does the job. . . . id like to see it a bit cheaper in future.
Looks like with all the T6F summer festivals some things got missed. . . . .
This was my look into the latest Power Bank - The ENGINSTAR R350
Enginstar 350W Solar generator, Power up your life.​
No more need to worry about the energy problem, here comes the Enginstar 350W Power station!
With 296Wh/ 80000mAh large capacity, you can power up your mobile phone, laptop, CPAP by AC, DC or USB port easily.
Not only can you charge the power station by wall charger or car charger, but also by the solar panel.
No hassle of fumes and noise, it’s designed to for camping, hiking, picnic or emergency situation.
NOTE:
  • How to make the DC outputs keep ON? If you need to supply power to the car refrigerator, you must double-click the POWER button quickly in 3 sec, so that the DC output will KEEP WORKING until the battery is out of power.
  • The max output of USB-C is 18W, please don't charge your iMac by this port, charge it by AC output.
Specifications:​
Battery Type: Lithium-ion
Capacity: 296Wh (80,000mAh,3.7V)
Input:
Charging Port: DC 5.5 x 2.1mm, 12V-25V, 65W max
Output:​
AC Output: Total 220V, 60HZ, Pure Sine Wave, 350W continuous, 700W peak
Wireless Charger: 5V 2A, 10W
DC Output(x3): 2 x 12V 8A, 1 x 24V 3A
USB-A Output(x2): Total 5V 3.1A max
USB-C Output: 5V 3A, 9V 2A, 18W max
Bulb Type: LED Flashlight with 3 mode: Light, Strobe, SOS
Lifecycle: >1000 Times
Working Temperature Range: 0 - 40 C / 32 - 104 F
Weight: 6.4 lbs / 2.9 kg
Dimensions: 8.6 x 6.7 x 6.7 in / 22 x 16 x16 cm
This is my unit:
in the box you get a PSU charger and 13a plug,
PLUS
a 12v car charger lead and MC4 solar input lead - which is nice.
the unit arrives about 50% SOC which is correct for lithium cells.
size wise you can see that it sits in between the ALLPOWER 372 and ECOFLOW 650 units.
one notable thing is its nice and light , , , im wondering if they are using pouch cells internally? (well have to wait for a tear down )
1st test was the good old air pump. - 260W no issues.
next up was hair clippers . . .
and battery hair clippers. . .
we took this unit to Busfest 21, and T6F Autumn Gathering.
it got passed around and used a fair bit.
one popular feature was the wireless charging pad on the top. (im not a fan of these, but thats just me)
loads of people were charging tire phones via the pad,
people with a USB cable were charging tablet and phones.
@czmate1999 was interested to see if it would run my compressor fridge, so we plugged in BOTH fridges via the 240v side and a 4way power lead.
we used the 12v outlet socketq to run our small 300w BESTEK invwerter, which it did . . . but if you tried to pull more than the 8A from the socket (about 100w ish) the unit would shut down.
you cant charge via the USB-C port wich is a shame . . . the max output is 18W, so no IMAC charging.
the input is Charging Port: DC 5.5 x 2.1mm, 12V-25V, 65W max
that applies for SOLAR too via the included lead.
thats a VOC max of 25V.
as long as you stay under the 25V VOC you can over panel the unit.
@czmate1999 connected a 100W Renogy panel to it and got a steady 55w charging.
ill do some more testing shortly.
ENGINSTAR - Solar charging.
here is a quick test.
the input is limited to 65W . . . .
so lets see what happens when we over-panel the input . . . .
just remember to stay UNDER the 26V VOC MAX, that means you need to connect panel together in parallel with branch connectors . . . . NOT IN,OUT,IN,OUT series connection
i used a 4 to 1 branch connector like this one. - ANFIL T-type Branch Cable Connectors Coupler Combiner Solar Panel - 1 Male to 4 Female (M/4F) and 1 Female to 4 Male (F/4M) : Amazon.co.uk: Business, Industry & Science
you can get two way ones too . . . - https://amzn.to/3mP5rCj
now for the testing . . .
First up we have a 160W Flex panel from Photonic Universe . . . . (this will be fitted to the T6 roof one day)
its rated @ 160W with a VOC of 23.9V
connected to the unit . . .
power wise we are charging at around 55W . . . so no issues here.
next up lets go large . . . . 220W.
i have two LENSUN Flex 110W panels. Combined they will generate upto 220W
ill connect then in parallel with the branch connectors.
They are rated at 21.3V VOC max.
connecting both to the branch connectors . . . .
we get this - 220W array.
power wise . . . . again around 55W max.
Conclusion.
The ENGINSTAR is similar to the ALLPOWERS and ECOFLOW, where you can over-panel the solar input.
it will take the max it can from the array, in this case around 55W. - and ignore the rest.
it seems to do this by current limiting the input. ( around 5A )
that means you can add as much solar as you want . . . . BUT you MUST STAY BELOW the max VOC - in this case 25V.
518wh... £309 with the promotion.
£0.59 / Wh
Thanks to @czmate1999 for the heads up.
Screenshot_20211213-165055_Amazon Shopping.jpgScreenshot_20211213-165044_Amazon Shopping.jpg
EcoFlow DELTA Pro Portable Power Station​
the Ultimate Lithium pack?
Now with Lifepo4 and 6000+ charge cycles (instead of 800+ on previous units)
Specs​
Net Weight​
Approx. 99lbs/45kg
Dimension​
25*11.2*16.4 in/63.5*28.4*42cm
Capacity​
3600Wh
Extra Battery​
Support up to two DELTA Pro Smart Extra Battery/Smart Generator
AC Output​
4 outlets, 230V/13A, 3600W total (Surge 7200W)
Max Device(s) Power Supported by X-Boost​
4500W
USB-A Output​
2 ports, 5V, 2.4A, 12W Max per port
USB-A Fast Charge​
2 ports, 5V, 2.4A / 9V, 2A / 12V, 1.5A, 18W Max per port
USB-C Output​
2 ports, 5/9/12/15/20V, 5A, 100W Max per port
Car Power Output​
12.6V, 10A, 126W Max
DC5521 Output​
2 ports, 12.6V, 3A, 38W Max per port
Anderson Port​
12.6V, 30A
AC Charging Input​
2900W Max, 230V~12.5A
Solar Charging Input​
1600W Max, 11-150V, 15A
Car Charging Input​
Support 12V/24V battery, 8A
Battery Chemistry​
LFP
Cycle Life​
6,500 cycles to 50% capacity, 3,500 cycles to 80% capacity
Shelf Life​
1 year (after a full charge)
Connection​
Wi-Fi, Bluetooth, wired
--- New Product --
"Oops i did it again" - wasn't that a lyric from Britany Speares?
well I've gone and truly done it now . . . :oops::oops::oops::oops::eek:
Bluetti AC200MAX - 2048Wh, 2200w/4800w,
12v/240v/USB/USB-PD/Wireless Charge/Solar MPPT
Its got everything !!!!!
SPECIFICATIONS​
Battery InfoBLUETTI AC200PMAX
Capacity2048Wh(36V,57.24Ah)
Cell ChemistryLithium Iron Phosphate(LiFePO4)
Lifecycle3500+(to 80%),6000+(to 50%)
Management SystemBMS, Over Voltage Protection, Short Circuit Protection
PortsRelated Parameters
AC Outpot230V, 50Hz, 2200W (4400W Peak)
USB Output2*5V/3A USA-A
2*18W USB-A 18W
1*100W USB-C
DC Output1*12V/30A Super DC
1*12V/10A Cigarette Lighter Port
2*12V/10A DC 5521 Output
Wireless Charging2*15W Wireless Charging Pad
Solar Input 900W(10-45V)Max 15A
AC+Solar Input1400W Max
Car Input11.5-14.5V; 23-29V, 7.9-8.4A
ScalabilityExpandable W/Up to 2*B230 or 2*B300
GENERALRelated Parameters
Weight28.1kg (61.9lbs)
Dimensions (LxWxD)42 x 28 x 38.65cm( 16.5 x 11 x 15.2 in )
Operating Usage Temperature-4-104F (-20-40℃)
CertificationCEC, DOE, FCC, QC3.0, CA Prop 65
Warranty24 Months
Optional AccessoryBLUETTI SP200 Solar Panel
IN THE BOX​
ProductQuantity
AC200MAX Power Station× 1
T500 AC Adapter & Cable× 1
Warranty Card× 1
PV Charging Cable (XT90 - MC4)× 1
Car Charging Cable (XT90)× 1
User Manual× 1
Car Charging Cable× 1
Certificate of QC PASS× 1
1. BRIEF INTRODUCTION For I/O capability, the AC200MAX features higher continuous output power at 2,200W from its pure sine wave inverter,
100W PD3.0 USB-C port,
upgraded MPPT controller which now handles up to 900W solar input,
and built-in 30A NEMA TT-30 outlet designed for RV crowds especially.
Most significantly, considering customers' feedback, comments, and product upgrade need, the BLUETTI AC200MAX now supports Bluetooth connection and the new BLUETTI Smartphone App (iOS & Android) remote control.
Furthermore, the AC200MAX also supports up to 2 expandable battery packs, using either the BLUETTI B230 or B300. With 2 BLUETTI B300, the capacity of AC200MAX then will expand to a massive 8192Wh to run your every essential needs at home or on the go for hours, days, or even more than a week!
user guide : https://cdn.shopify.com/s/files/1/0...80-02_BLUETTI_AC200MAX_11.25.pdf?v=1637829321
one of the reasons why i chose this unit is that the DC INPUT can take 10v to 145v DC that means that you can use ANY solar panel,
the other non-max unit is locked at 75v mon for solar - meaning you need three 100w panel min to work on solar . . .
plus it has 4x 240v sockets and slightly more power
this is my unit . . .
its a monster and weighs a ton . . .
the included cable set with XT90 connectors . . .
paper works . . .
and the BIGGEST PSU I've seen . . . its 58V @ 7A and an absolute BRICK.
close up . . .
its huge @ 2048Wh . . .
that's equivalent to 2x 100Ah Lithium's,
or 4x 100Ah AGM batteries storage capacity,
it comes with a BT APP. . . .
that seems ok,
not as polished as the ECOFLOW APP. . . . . . but functional.
-- NEW PRODUCT --
Anker Portable Power Station 256Wh, 521 Portable Generator
About this item​
  • Extremely Durable and Long-Lasting: The portable power station is equipped with premium LiFePO4 batteries that offer 6 times longer lifespan, a drop-proof unibody structure, and industry-standard electric components for enhanced durability.
  • Unprecedented 5-Year Warranty: Instead of 2 years, 521 Portable Power Station comes with an exclusive 5-year warranty for a guaranteed, worry-free experience.
  • All the Ports You Need: Time to get rid of bulky adapters because charging your laptop at fast speeds only requires a single cable. See the power station recharge itself and give a high-speed charge to a wide range of devices thanks to 2 USB-A ports, an AC port, a USB-C port, and a car outlet
  • Huge 256Wh Capacity: The high capacity portable power station pumps out 256Wh of power—the perfect companion to charge your devices and small appliances during a weekend trip.
  • What You Get: Anker 521 Portable Power Station (PowerHouse 256Wh), DC adapter, car charging cable, welcome guide, our worry-free 5-year warranty, and friendly customer service.
heres mine,
unboxing and testing coming up soon . . .
-- NEW PRODUCT --
About this item​
View attachment 157160View attachment 157162View attachment 157161
heres mine,
you are bonkers!!! :)
BLUETTI Portable Power Station EB70 1000W/716Wh Power Generator with 2 230V AC Outlets,100W USB-C,Regulated DC 12V,Wireless Charging,LiFePo4 Battery Solar Generator​
-- NEW PRODUCT --
About this item​
heres mine,
Does anyone have any real world experience with this unit now it's been out a little while? I'm looking for something modest (cheap) that will let us keep the Dometic CFX3 fridge powered overnight in the awning. Reckon this little chap should manage for a couple of nights if I've done my maths right.
@hunta it's a brilliant little box that has the Anker quality that we know.
Just been using ours all weekend camping.
200w mains was well enough to run the air pump, fridge, lights, etc etc. While setting up.. then mainly used for USB charging and USB camp lighting.
20220601_165522.jpg20220601_165532.jpg20220601_211430.jpg20220601_212522.jpg20220602_151012.jpg
It's only 270 odd Wh capacity.
So if you want longer run time, look at the 500-600 Wh units.
Bluetti and Ecoflow do them, plus Anker is releasing a new unit with larger capacity soon.
