On my 17 plate T6 the sliding door has partly jammed when unlocking the door it jumps about 6 mm but not the full 25 or so required to enable the door to slide correctly , of course the van is 5 months out of warranty, I tried the usual WD 40 trick on all the moving catches can any one advise me on what the problem may be ? I am assuming that some mechanical part of the sliding mechanism pushes the door away from it's closed position .Any advice appreciated.
