(Side Assist) / (Blind Spot Detection & Rear Cross Traffic Alert) retrofit
Did you go for that one in your build --> Deaky’s Kombi to Camper journey
I mean the revision A of the PDC - 1K8 919 472 A
Just asking as I'm a bit challenged with same fault as @hanzz using revision 1K8 919 472 C. Fortunately it seems not to affect the operation but just can't sleep at night :sleep:
Could you please share the current scan of the module 10?
Meanwhile...
The OEM
1K8 919 472 C, well - the colours... and slightly different distance thresholds...
EDIT:
Later realized that the distance bars are "grayed out" when van can't move e.g. Park is engaged, although true only on "main" display. Also the warning tone turns off when gear in Park.
Meanwhile...
The OEM
i didn’t go for that one from carsystems. I’d already got the module and adapter lead. Mine is a revision C. Everything is working as it should apart from VCDS bellyaching about a missing ROD file.
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331613113703
Coding: 0021191111
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: N/A
VCID: 377DC74A8E33493EFA-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VN75)
1 Fault Found:
12718592 - ROD - Unknown Error Code
- 00 [009]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 50078 km
Date: 2020.06.02
Time: 09:23:38
Coding: 0021191111
ROD: N/A
1 Fault Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 50078 km
Date: 2020.06.02
Time: 09:23:38
Ok, thanks. I believe we'll get in next few days a solution for the missing ROD-file . I requested Ross-Tech for a special .lbl-file to associate with T6, (or to include this combination in their next build). Then we'll have something like this. Without the file the association needs to be done manually at every session :mad:.
Code:
                Address 10: Park/Steer Assist       Labels: 5Q0-919-294.clb
Control Module Part Number: 1K8 919 472 C    HW: 5Q0 919 294 A
  Component and/or Version: PARKHILFE 8K  H03 0480
           Software Coding: 0001151111
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_EPHVA18VW364GP00 001007 (VN75)
                       ROD: EV_EPHVA18VW364GP00_VW32.rod
                      VCID: 3728216D1E44FA53A21-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 36693 km
                    Date: 2026.14.06
                    Time: 14:45:52
Do you have audio warning and warning on the Instrument cluster?
Neither :cry:
Unfortunately nothing obvious in the PDC to switch on audio warnings for 3C in there.... so not sure if the data displayed on rear view camera display is actually even bypassing the PDC thus 5F would independently fill in the extra sectors from 3C data... :sleep:
However interestingly Skoda's (using the same 3C on MQB platform) owner's manual states (vaguely) that vehicles without parking aid get warning tone/information in the instrument cluster...
These are the visual RTA warnings normally produced by the IC.
@dnoermann would you mind to confirm for all of us if these messages are actually present in the IC firmware string?
I tried myself but the file has vanished;).
For audio RTA warning coming from the IC there might be some coding/adaptation modification required between few modules and potentially 17 included :whistle:.
I didn't get a chance to verify this myself (yet) but apparently there are few side effects of this upgrade.
1. Automatic activation of PCD system, by simple approach to obstruction at low speed.
2. Dynamic guide lines, driven by steering wheel movements.
3. Non OEM front camera activation on DM via PDC OEM console switch.
:cool:
