Shuttle\Kombi Twin Sliding Door Cable Run
saintclarkey1
Hi All, Apologies for starting a new thread but I couldn't find the answer I was after anywhere else. Basically as my shuttle has twin sliding doors I need to think about a cable run from my leisure battery (under the drivers seat) to the rear of the van where my 12v fuses box will be for lights, usb's, fridge, tap pump, SMEV ignition etc etc. The pop top goes in next week so I was thinking of taking a 16mm2 cable form the battery under the seat up the B pillar along the VW wiring loom then down the d pillar before I lose access to that loom (the pop top will case it in). It will all be thoroughly wrapped in Tesa Tape but just wondered if anyone else had better ideas for the twin sliders? It's a LWB as well so it's a fairly long run but with 16mm2 I don't think the voltage drop will be to bad.
