I fitted some Audio Frog replacement speakers with crossover in there but they were small.Just wondering if anyone has fitted crossovers into a T6.1 door card? Hardly any flat surfaces to mount on (not to mention the sound deadening), so I cant see where there is room?
Any pics?I fitted some Audio Frog replacement speakers with crossover in there but they were small.
No pics sorry forgot!Any pics?
I've been looking further, I can't get my crossovers to fit anywhere in the door cards. I will have to investigate if there is any space behind the dash or in the A-pillars.No pics sorry forgot!
The audio frog replacement speakers I got Skipton car audio came with replacement door and a-pillar tweeters and each speaker came with a crossover. They were small enough to fit adjacent the door speakers and the tweeter ones fitted behind the a-pillar trims.
I would say the sound improvements were good but later on I added a sub under the passenger seat and a 5 channel amp (only 3 used) from @Absolut5 complete with wiring loom, now the sound is amazing.
Thank you fir that. However my crossovers must be bigger and the door card won’t go on with them tucked in there.
I might have a look if there is room behind the glove box. If I can work out how it comes off. Running active would be a last resort, but it’s looking like it may happen.In my last two cars I've just run the mid speaker wires only to the door and left the crossovers under the dash behind the glovebox or when the crossovers have adjustable roll off or attenuation settings actually in the glove box to allow for tweaking without too much messing about, failing that go fully active and dump the passive crossovers altogether.
Pop the green cable holder out , move it over and twist the straight like the pic, or as mentioned run them active if possible
I put some in stick to the inside of the door skin and when the windows wound down it started to rub. I also put some on the inside of the door card. This mad it very difficult to get the door card back on andI had to pull some off in quite a few places.Thread resurrection.
Would you say there is any room at all in the door cards for extra insulation? I have already got sound deadening material ( fitted by SCR ) but fancy getting some more insulation of some sort in there to help suppress external sound.
