Hi
I've decided to have the Eibach Coilovers fitted as the dealer is giving me a great deal (to make up for some appalling service in the past)! I just need to advise how low I want it setting up. I plan to keep the standard rake (lower at the front) and so lower the same amount all round.
My question is whether there is a sweet spot in terms of looks/handling and comfort. If the drop is adjustable, say from -30mm to -65mm, how much does the chosen drop impact the effectiveness of the shocks? I am assuming the ride will be "worse" wound down to -65mm compared to set at -30mm as there's less travel available in the shock?
If that's correct, is it linear, or would an extra 10mm drop from -55 to -65 have a far greater effect than a 10mm drop from -30 to -40?
