Retrofit Cruise Control To 2017 T6 - Been Told Can't Do It!!??
Discussion in 'Electrics, Lighting, ICE, Security' started by record1976, 28 Mar 2019.
  1. record1976
    record1976 New Member
    Hi,
    I'm desperately hoping that someone here will tell me that this is not true!
    Just bought a VW T6 Transporter Shuttle, booked in for B14's, wheels on order...everything lined up.
    Just had a call from local VW garage saying that they can't do the retrofit cruise control I booked the van in for because VW has come back to them and said on that some change recently means that this is now only a factory fit option.
    Cruise control is an absolute must for me, I would never have bought the vehicle but never considered that it would not be possibly to retrofit.
    Help!
  2. Pauly
    Pauly Senior Member VCDS User Admin Moderator
    Map
    It can be done, replacing the stalk is the normal method and adding it in as you would on most VAG vehicles
    If they can’t do it you are prob best going to a decent retrofit, I’m assuming you have taken it to the VAG garage in Exeter are they the ones saying it can’t be done ?
    I know someone in Plymouth who can do it for you
  3. record1976
    Yes VAG garage Carr's of Exeter but also local independent VW garage said can't get parts for T6 yet!?
    Would appreciate recommendation in Plymouth.
  4. Ashypants
    Ashypants Member VIP Member
  5. Pauly
    Map
    Did you try Volkscraft ?
    Matts been on here in the past would think he could do it
  6. volkscraft
    volkscraft Member
    Map
    Speak of the devil and he appears! Thanks for the recommendation Pauly, hope you're well mate? I'm looking in to it right now.
  7. Dieseldonkey
    Dieseldonkey 150 DSG Shuttle Conversion VIP Member T6 Legend
    Map
    It was first thing on my list for my Shuttle. Had it fitted by Professional Retrofits. Something to bare in mind. Even though your Shuttle is a euro 6, you can fit the cruise on a stalk, like euro 5's had. However, if your thinking of a MFSW in the future, then the euro 6 wheels have cruise switches located on them instead of a stalk. However I believe you can put a euro 5 Highline MFSW on instead though, minus cruise switches.
  8. volkscraft
    volkscraft Member
    Map
    Just spent an hour on the phone to TPS. There are about 100 different BCM's for the T6 and As @record1976 's van doesn't have fog lamps it will require a body module upgrade too apparently. @Dieseldonkey Did yours need a BCM replacement? They're £320+ Vat alone apparently.
    **Edit** Just noticed @Dieseldonkey 's is a Euro 5. Much more straight forward on a euro 5 it seems. They use similar (if not the same) part numbered BCM's as T5.1.
    Wilmabeast likes this.
  9. Dieseldonkey
    Map
    No. Mines a 2016, but it's a euro 6. The euro 6 engine appeared much earlier in the people carriers, than it did in Kombis and PVs. In fact I don't think there was a euro 5 T6 Shuttle. Existing factory BCM took the cruise without issue. I wanted cruise on the stalk as I didn't, at that time have a MFSW and actually preferred it in this location. I've just retro fitted factory fog lights too. No issue there either. Just plugged straight into the original BCM connector. Here's my BCM if this helps
  10. volkscraft
    volkscraft Member
    Map
    The part number combinations have a 'Colour code' Which is a variant of that part number not listed on the part or VCDS usually.
    For instance the one listed for @record1976 's 2017 Shuttle in standard form is 7E0 937 090B ZDV. The ZDV part is the colour code which states 'without cruise or fog lamps'. There are 270 versions of the 7E0 937 090B which are differentiated by colour codes. There are 55 different sections of ETKA for the BCM, each with a slightly different date range or base spec and each potentially with hundreds of colour code variants inside!
    Without counting, there could be thousands of BCM variants, It truly is a retrofitters nightmare!
    Aircon and andys like this.
  11. andys
    andys Senior Member VIP Member T6 Legend
    Well b****** me! This may finally be the answer to the very first T6 issue I had, why I couldn't get retrofitted Safelock coding to work on mine, even though it was fitted with a BCM with the same number as all the ones that did have it.
  12. Dieseldonkey
    Map
    Ah. Afraid I'll have to pass then as I've no knowledge with this bit. Maybe I was just lucky with the BCM I had fitted in mine from the factory, as it took the cruise and fog/cornering light wiring without issue.
  13. Dieseldonkey
    Map
    Just giving this some thought. @zebra quoted this in his very useful fog light retrofit post.
    This is the power supply wire into the BCM that the fog lights use. Like @zebra mine was already on situ. Would establishing if this wire is already in place help you in working out if the BCM can actually do something that's not listed against it. ie cruise and fog lights. Just an idea.
  14. volkscraft
    volkscraft Member
    Map
    I think all of the connectors are the same, It's more that the BCM firmware or chipset up will be different to support these features.
  15. Give HazzyDayz a ring.
    That fitted it to my 2017 Cali
  16. volkscraft
    volkscraft Member
    Map
    HazzyDayz certainly seem to know a work around with the BCM, they are saying £200 + Vat extra if you don't have front foglamps. Either that or they have a cheap supply of BCM's as they're £300 to us from TPS.
  17. HootingOwl
    HootingOwl Senior Member T6 Guru
    HazyDayz are used by VAG dealers all over the UK because they understand the VW electrical system. Dealers can only follow instructions in the workshop manuals.
  18. record1976
    Just wanted to update the thread on the outcome.
    A trip to Hazzydayz yesterday and they fitted a multifunction steering wheel with cruise control function and all working great!
    They were more than happy to fit the steering wheel I bought on ebay.
    Thanks Hazzydayz team!
  19. True Romance
    True Romance 204 TDi DSG LWB VIP Member T6 Guru
    Map
    Awesome! Glad you got it sorted. T6 forum to the rescue again :)
  20. Tanzi
    Tanzi New Member VIP Member
    Map
    Dieseldonkey,
    Were you able to code this with VCDS, just scanned my BCM with Carista and it appears to be the same as yours but heard you need different software to code it? TIA.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
