Retro fitting cruise control onto a converted T6 has caused component protection mode, a new BCM and still no further forward
Bliismoments
Hi all,
We bought a converted T6 startline 2016 in July, having done plenty of research over the lockdowns (including much of the sage advice on here, so thank you!) and it has been great, completing 2.5k miles in three months with long trips from Scotland to south Wales and France. Loved it. I wanted to put cruise control in as we were planning on doing more long journeys and with a slightly dodgy right ankle from a break 30 years ago, it was something I'd wanted. Having done more research and conversations with garages which all suggested it would be possible and not too expensive, a former VW master engineer agreed to install.
AFter a couple of hours things were not looking good as nothing was working on the vehicle, further investigation led to component protection mode being the culprit. It was then moved to the local VW approved van centre where they installed a new BCM and are unable to find why the control modules are no longer talking to each other. They are back and forward with VW technical in Germany and with the bill now reaching £3k, are still no further forward.
Have I really burnt £32k on a van that broke after trying to put a genuine VW part into a VW van with a skilled VW team looking at it? I don't doubt the van centre's abilities but they are going to have another go at it after Xmas so if that doesn't work, anyone want to buy a project? :rolleyes:
Seriously though, what do you think my options are?
you just want basic CC?
not ACC adaptive?
i added CC on my T5.1 very easy . . . just a couple of wires and a new stalk...
Hazy Dayz offer it for £375+vat
This is for the supply and fit of cruise control to your VW Transporter T6.
This is the stalk variant, we can also offer the Multifunction Steering Wheel with cruise control,
please see this link for more info.
- Genuine Vw parts with 2 year warranty extended 3 year warranty on brand new vehicles.
- Professional Installation with 2 year warranty.
- Call out service available.
- Optional Basic DIS upgrade at reduced cost.
- All Models from MY2016>.
Special Offer: If your vehicle doesn't have the Basic DIS for mpg, journey time etc,
this can be added at the same time for a reduced cost.
Please select this option below.
Installation takes approx 2-3 hours depending on model type and requirements.
Basic operation: Drive the vehicle above 20mph, press the set button, the vehicle will now stay at
this speed. You also have a + button to increase speed and a - button to decrease speed. The clutch
and/or brake will cancel it the cruise control, you also have a resume button to resume previous speed.
This will operate the exact same as factory fitted. Once the cruise control is turned on, a green light
with cruise control symbol will be displayed on the dash. This light is factory installed for this purpose.
Supply & Fit £375.00+VAT
Reactions: mmi
here is more info on ACC,
Thanks for your time in replying but that's not what I need. The VW master tech fitted the cruise control and now the van won't even lock, let alone start. I know it seems easy and that's what all the research I did would suggest, but the electrics have broken and won't start again.
can you post a VCDS scan?
to see what modules are responding?
what about the old BMC?
has the new BCM been installed correctly?
is it awake? - have you got comms with it?
without VCDS or other scanner you are very limited in diagnostics.
first thing to do is scan the van for codes and list here:
On 2016 T6 only component protection participants are (1) "Control unit for distance control" = Adaptive Cruise Control radar, (2) Dash Instrument Panel and (3) Infotainment.
not ACC adaptive?
Is it the basic Cruise Control or Adaptive one being retrofitted?
He didn't know what he has doing and has broken your van.
Not sure why you should be stumping up the 3k..
Might be worth speaking to a retrofit specialist to see if they are willing to work on it - then getting it recovered
