Replacement MAF sensor connector
LambethBoy
204 DSG 4Motion
VCDS User
Does anyone know if this part is available from VW at all? Mine has split at the latch part just under the grey securing pin and managed to wiggle its way loose and gave me a coil light and stop start error today going to tape it up for now but could really do with the proper replacement part. :thumbsup:
Agree it is best to contact the van centre, or even any vw dealership, not likely to be specific to vans only. They do seem to be fairly generic vw connectors. For example check out "VW AUDI VAG 1J0 973 704 4 Pin MAP Electrical Sensor Connector Plug - 1J0973704" on ebay. Obviously, check how many pins your particular connector has. They can also be tricky to crimp together and assemble. I have just tried this on my fuel temperature sensor connector (2 pin) which is working for now but I'm waiting for delivery of a more expensive pre-wired connector so that I only have to join the cut conductors. I'll feel more confident with the repair then.
The part number is on the plug, order one and then use a pin removal tool to remove the existing pins and transfer them to a new plug.
They are are quite common holders so might be just as easy to get one off ebay and withdraw the pins..
