Renogy charging parameters
Drebin
Hi all,
I know this has been discussed previously but I can't ascertain any real answer.
I have a victron dc-dc smart charger and a renogy 100ah smart lithium battery.
Has anyone figured out the settings I should use or have one that seems to be working well for them.
Many thanks in advance
Screen shot your Orion setting pages.
Also are you using the IGN feed (on/off) on the H pin? / BCM feed? / Or Automatic?
Post a pic of the cables on the Orion also.
And while your at it post a few screen shot of the Renogy battery status pages too.
Heres mine. I don’t use engine shutdown connection as I use a dedicated engine run signal from the BCM that connects to the H remote connection on the Orion
Hi all,
If the charging profile spec is available from renogy i.e. Bulk-absorption-float, voltages & times. You can create a custom profile specifically for your battery.
Currently just using the smart lithium preset which I think is the same as @Deaky
But I'm using the automatic engine shut off detection.
It's the non isolated
