Hi all
been having some issues with a Renogy 500A, and thought we had it cracked... but not so...
First issue was that the head unit of the 500A was not showing the drain at all, although it was showing battery voltage changes.
We sorted that out.. (slight mis-wire) and I went away last week and the LB supported the fridge and diesel heater and lights. All seemed good. But, running the engine shows no charge from Alternator to LB. However, over a 3-4 hour drive home.. the 500A still was saying no charge into the LB, but it did.. it was fully charged, although not according to the 'battery capacity pic on the 500A, and it doesnt show a positive charge. Had to reset to 100% manually, after checking it.
I have checked the fuses, and all are good.
One thing I have found. The lead that comes out of the D250SE (bottom one) goes to the front fuse panel (red lead) and according to the CTEK manual the black should go to vehicle earth. It is connected to the top right CTEK terminal, which IS the earth connection on there.. but knowing how fussy it is where the earths are connected. I am wondering if thats a mistake?
Be grateful if anyone has run these devices together could advise how theirs is done??
Thank you
Pete
Thank you
Pete
