Hi all,
Looking for some real-world experience before I decide how far to push this.
I’ve got a Renogy 170Ah LiFePO₄ (RNG-BATT-LFP-12-170) in my T6.
Van converter who supplied it has disappeared, so I don’t have the purchase invoice — only the battery itself and serial number.
Serial: 22RBL1006xxxxxx (so looks like a 2022 manufacture build)
Fault
Battery appears to have failed internally rather than install related.
Bench test results:
• Charged via Renogy 20A mains lithium charger to 14.28V
• Measured directly at battery terminals
• No load connected
• Voltage drops to 0V within about 40 minutes.
• No low-voltage cutoff behaviour
• My second identical battery works perfectly when isolated in same setup
So looks very much like BMS collapse.
The issue
Renogy won’t even assess it because I don’t have an invoice, despite the serial clearly dating it within warranty and the supplier no longer existing.
I’m not trying to blag a free battery — just want it tested properly.
Question
Has anyone here actually managed a Renogy warranty without proof of purchase?
Or did you have to go via distributor / consumer rights route?
Interested to hear what worked before I go down the wrong rabbit hole.
Fault
Bench test results:
• No load connected
The issue
Question
