Removing light diagnostic check with VCDS after installing LEDs
xnNntMw7n
Hi all,
I am looking for some help with coding out the bad bulb warning on my T5.1. I have had the Philips H4 and W5LEDs installed for a little while. When turning them on I get the land diagnostic warning light on the dash.
In VCDS I have modified Bit 16
  • Lamp Diagnostics for Low Beam active - unchecked
  • Lamp Diagnostics for High Beam active - unchecked
When reading the codes, I get 4 faults. Lamp for Low Beam, Left and Right. Lamp for High-Beams Left and Right.
I largely ignored this in the past but seen as I had VCDS out to sort another error out, I thought I would take another look.
Does anyone have any pointers on how to clear this on a T5.1?
Thanks in advance!
