OK, I need to relocate the hot air outlet from the Eberspacher, as it was originally put in a position by a converter (AJC) that I have since found out is a stupid place to put it. As whenever I try to find a set of furniture the hot air outlet in in the way so the furniture wont fit.
I've now decided the only course of action is to move the outlet.
So considering this I have to choose from either under the drivers seat, or through the floor just behind the drivers seat. I believe that you need to feed the hot air duct up in the chassis rail? Anyone have any photos of the route?
Lastly I will then have quite a big hole in the floor that I need to close up. Looking for suggestions as the the best way to do this, would sikaflax a stanless steel plate over the hole be the best method?
Thanks for any help with this.
