Furgoavispa
Possibly.....
It would have to be an isolator switch beefy enough to deal with the max current..... but some dc-dc charger dont like having the battery disconnected, possible internal damage and faults stored.....
It's much better to run dc-dc chargers with an ignition/run feed that can easily be switched off. (A simple in line low current switch will suffice)
Hello from Spain and excuse me for my bad english
I bought a Redarc 1240D from Travelvolts (thanks Martyn) and I tried to switch off the blue cable (ignition feed) in order to stop charging my Fraron 100 ah lifepo4 battery when freezing and it does not works.
Without the ignición wire switched, the redarc just works charging the leisure battery when it detects over 13,2 V in the main batt and stops below 12,8 V
How can I switch off the redarc when freezing?
