RCD330 not working with reverse camera
zaibs
Hi guys,
I installed RCD330 (6RD035187B) to my van. I had to use MQB to PQ adapter to connect it and everything worked great. I then tried installing a reversa camera and can't seem to get it it work. I wired everything according to the diagram, including delay box and taking power from reverse light at one end and from the cig lighter fuse at the other end). I checked the set up many times now. I get "The rear view camera system is currently not available". But sometimes, I just get a black screen.
I bought a separate TFT monitor to investigate this, and everything works if I unplug AV cable from the headunit and plug it to the standalone monitor.
I'm now a bit lost as to where the issue is. Is it really with the headunit and can I check this without getting my hands on a new one? It does seem like the headunit is activated, because when I put the van in reverse, I do get a message about the camera. The headunit also came with a separate AV adaptor, so maybe the issue is there?
If anyone has any ideas or did a similar install, then let me know what you think could the the problem here.
Here are the pics showing the camera not working on the headunit, but working on TFT monitor. And the connection diagram I used as a reference.
Read fault codes from your head unit first.
You don't have to buy, maybe you can find someone local who could do fault read for you.
I managed to get it scanned and I see this:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 114855 km
Time Indication: 0
Date: 2022.07.08
Time: 08:00:17
I don't think this tells me much.
I also tested the adapter from AV to blue socket using the separate monitor and that worked.
Can you post complete scan for the whole vehicle?
Code:
Tuesday,26,July,2022,15:29:29:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 22.3.1.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZHX017101   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 5F 61
VIN: WV2ZZZ7HZHX017101   Mileage: 117250km-72855miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KB    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6189
   Revision: 23002001
   Coding: 00114014432401090000
   Shop #: WSC 24822 002 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056KB 004015
   ROD: EV_ECM20TDI03004L906056JT.rod
   VCID: 77FD5EDBCECD4D37FE-8023
   VINID: 9E60AAAAA1D8A98A00047040049B3EF3DB
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 43416000000070
   Coding: 307E4098256384850C760276A48321F3780000
   Shop #: WSC 35110 790 50316
   VCID: 3F8DF6FBA67DB577F6-806B
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 13101613471418
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7FBD-802B
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AJ    HW: 7E0 907 047 AJ
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 72EB6FCFA5AF281FC9-8027
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 329160591
   Coding: 62A0303A0A212032002009746C2B8CD40F80708F60CE4D60320400220800
   Shop #: WSC 35110 377 08192
   VCID: 2A5BB7AF45FF20DFB1-807F
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU024111663293934
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU023111663283715
   Coding: 1400A0
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag020 H08 0018
   Revision: --------    Serial number: 003V30030T5V
   Coding: 000000000000000000000000000000003230
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A7B87EFBD5F905FC1-806F
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 860 S    HW: 7E0 920 860 S
   Component: KOMBI         H03 1104
   Serial number: 00000000000000
   Coding: 150B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 387F9DE78353824F37-806D
1 Fault Found:
13654544 - Databus
          U1121 00 [009] - Missing Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 118
                    Reset counter: 164
                    Mileage: 114506 km
                    Date: 2022.06.28
                    Time: 13:15:04
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042205
   VCID: 68DF0DA79B73D2CF67-803D
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 143
                    Mileage: 114506 km
                    Time Indication: 0
                    Date: 2022.06.28
                    Time: 13:15:02
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1104
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADB77AF8D7FE0DF71-803F
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B7A73
   Shop #: WSC 29383 004 1048576
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001611151252
End-------------------------(Elapsed Time: 02:26)--------------------------
Could these CAN errors be related? I tried googling and it looks like they come from me fitting the aftermarket RCD330 unit. But I'm not sure if it is something to worry about as everything works perfectly except the camera.
Can you post complete unedited scan?
That was unedited auto scan. Here's the unedited radio scan:
Code:
Tuesday,26,July,2022,15:31:43:00009
VCDS Version Release 22.3.1 Running on Windows 10 x64(VirtualBox)
www.Ross-Tech.com
                Address 56: Radio       Labels: 5M0-035-1xx-56.clb
Control Module Part Number: 6RD 035 187 B    HW: 6RD 035 187 B
  Component and/or Version: Radio         541 5614
           Software Coding: 0E000440040005
            Work Shop Code: WSC 127395 840 08317
                      VCID: 4683E31FF1A7E4BFB5-8013
15 Faults Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 07:30:09
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 204
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 07:30:09
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 40
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 07:30:09
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00873 - Bass Speaker Rear Right (R17)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00870 - Bass Speaker Front Left (R21)
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 183
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:05
00871 - Bass Speaker Front Right (R23)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 183
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:05
00874 - Treble Speaker Front Left (R20)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:15
00875 - Treble Speaker Front Right (R22)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:15
00876 - Treble Speaker Rear Left (R14)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:15
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 00:00:15
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00110111
                    Fault Priority: 5
                    Fault Frequency: 9
                    Reset counter: 204
                    Mileage: 27780 km
                    Time Indication: 0
                    Date: 2018.06.15
                    Time: 08:48:19
00849 - S-contact at Ignition/Starter Switch (D)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 183
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 114855 km
                    Time Indication: 0
                    Date: 2022.07.08
                    Time: 08:00:17
I managed to clear all the errors but the one from camera by changing coding to use Radio instead of 5F after the head unit swap.
So at the moment I have no ideas but maybe try buying another camera and just seeing if it works. But since I know that the camera works with a separate monitor and the seller told me it should be compatible, this might be a waste.
Friday,12,August,2022,13:04:28:00009
www.Ross-Tech.com
VIN: License Plate:
Scan: 01 03 04 08 09 15 17 19 25 56 61
VIN: WV2ZZZ7HZHX017101 Mileage: 118440km-73595miles
Revision: 23002001
Readiness: N/A
Address 04: Steering Angle (G08ª) Labels:* 6R0-959-654.clb
Coding: 01
Revision: 00001002
Coding: 0000000003
Coding: 0400A0
Coding: 1400A0
Coding: 150B010300
Revision: B9081001
Coding: 042205
Serial number:
Coding: 000000
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5614
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 0E000240020005
Shop #: WSC 127395 840 08317
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 118446 km
Time Indication: 0
Date: 2017.01.02
Time: 13:57:34
Coding: 030B7A73
End-------------------------(Elapsed Time: 02:31)--------------------------
RCD330 (address 56) expects to see a dedicated module 6C-Back-up Camera (J772)?
What happens when you in Radio coding untick byte 03 bit 6 - the fault goes away? Anything on screen when in reverse?
Could this be the "6C" - what happens if you activate "6C" in the gateway installation list? Can you connect into 6C with VCDS?
Its not supported on the can gateway, tried and failed for another member recently
Sorry what exactly do you mean it is not supported? Are you talking about the camera or the headunit? Can you elaborate a bit?
When I untick byte 03 bit 6 the fault does not go away. I even tried clearing the error and it would still come up later. However, the reversa camera screen did stop showing when I put the van in treverse.
I tried activating "6C" but I could not connect to it via VCDS. It was unreachable and it didn't show any meaningful error. Also it didn't help with the issue.
The RCD head unit is not supported on the T6
I don't understand where this is coming from. RCD330 works with my T6 in every way except the reverse camera. I had to buy MQB to PQ adaptor, though. I also see other people on the forums using this combination.
Maybe this is part of the issue. But the camera plugs straight into the head unit, so I was thinking that it shouldn't matter.
If you have some details about this feel free to share, but I don't think simply saying "not supported" is true.
Yes it works on its own, but you cant add it to the can gateway as it is not available.
