Radar - upgrade city braking to Adaptive Cruise Control
Jeidmaster
My 2018 highline van is fitted with the radar on the front grill which and I just assumed it was for adaptive cruise control. I’ve tested the cruise control and it has buttons on steering wheel to set clear and turn on, off and while it works it certainly doesn’t slow down when catching up with other vehicles etc so no adaptive control.
I’ve since found other chats online regarding similar and people say it could be for city braking and nothing to do with cruise control. Ie van brakes itself if something jumps out etc
Does this sound likely or is cruise control just faulty. Is there any way of checking to see what I have
If you take up VIP membership one of the perks is that you can get a full build spec sheet from your VIN - then you know what factory options you have.
The radar is used both for ACC and what VW call "Front Assist" which is the emergency breaking. Some physical equipment on the grill AFAIK but what features it enables depends what was asked for at build.
If you don't have ACC at build retrofit might not be easy:
If you don't have this button on your MFSW
your van is most likely equipped with a FRONT ASSIST and standard cruise control via MFSW.
If you want ACC it can be easily upgraded.
Looks like it’s missing, just blank
How easy is it to upgrade, what’s involved is it a diy job. New parts to buy etc
How do you become a vip to gain access to info you mentioned
It is a 100% DIY job.
You just need to replace your MFSW buttons with 7E0959442A, exchange your radar and adjust the coding of your ECU(BYTE 5) & ABS(BYTE 17).
Oh it is a different radar unit then? I learned something today :thumbsup:
Sorry to high jack this thread ,, has anyone carried out the upgrade from no cruise to adaptive cruise on a t6 is there a guide/ how too including parts list etc
There is no legitimate upgrade path you will need to speak to a retrofitter or someone offering cracked radar units to progress with this
No you can upgrade it if you want but you need to find someone to assist you as you cant do it all yourself
Hi Pauly ,, any recommendations? ,, my van has the radar distance sensor on the front but no cruise as yet , I’d like to use steering wheel style controls but if I can make it adaptive if that’s the correct term ( so will slow and regain speed in line with the traffic ahead without any input from the driver) then it would be nice to do that too seems most mk7 golf controls have the distance button where as standard t6 cruise dose not.
I would start with your closest retrofit company and go from there ?
I need this on my BUS.
Any idea on a part number for the radar with the correct swap code programming?
If not, what's needed to change the swap codes?
I have standard CC, with city braking RAdar, and a MFSW with acc buttons.....
So I need to change swap codes in existing radar or replace with one that has them already?
This is brilliant decision.
The radar part number is the same regardless of what SWAP code has been activated at factory.
In order to activate the ACC your current SWAP code
10003400 MRR-Paket 4: FrontAssist inkl. CityANB (ohne ACC)
needs to be replaced with one of the following:
10003200 MRR-Paket 2: ACClow (ACC FTS) + FrontAssist inkl. CityANB for max ACC speed of 100mph
or
10003700 MRR-Paket 7: ACChigh (ACC FTS) + FrontAssist inkl. CityANB for max ACC speed of 130mph
I have only used 7E0959442A and 6C0959442B for the ACC on the T6.
This is quite sophisticated process and requires additional tools.
This is very easy way especially that the CP can be disabled in the radar altogether.
The whole process of radar exchange is plug and play. Radar can be swapped within 2 minutes and only flat screw driver is required to release radar top holder. No calibration nor alignment is required afterwards.
or
Great, can you point my me in the right direction to get a radar with the correct swap codes? Here or via PM?
I've got my MFSW, from my other van.
And a couple of BCM repair wires, for the LIN Bus and Power to MFSW.
Haven't got anywhere with a Radar with correct swap codes yet.
2018 Highline with MFSW and I’ve got the front radar for brake assist.
A. How useful /reliable is the ACC?( it’s a 6 speed manual)
B. Is there anyone who could guide me on the parts needed and do the coding?
Did you do the conversion?
I was just wondering how ACC would work with a manual transmission. Unlike the dsg that will chnage gears automatically as required , I assume you nned to chnage gears manually etc. as required?
