Yep. The thermostat is related to the temp of the environment and not how hot you want the air coming from the heater.Question - does the propex only have one heat? I.e the thermostat hot to cold only changes the temp it shuts off at?
Whilst the heat coming out feels ok it’s not as hot as I was expecting but I suppose it will quickly build up and heat the van
No probs, thanks @DaveyB . Maybe I was just expecting too much. I had it in my head the heat would be so hot I wouldnt be able to hold my hand in the air as it came out the vent. I had it on for about 30 mins there and the van was heating up nicely so its probably fine. It is mighty cold here just nowYep. The thermostat is related to the temp of the environment and not how hot you want the air coming from the heater.
I know what you mean. I was in -7 in mine last weekend and the heater just tickles away until it has warmed the volume of air in the van.No probs, thanks @DaveyB . Maybe I was just expecting too much. I had it in my head the heat would be so hot I wouldnt be able to hold my hand in the air as it came out the vent. I had it on for about 30 mins there and the van was heating up nicely so its probably fine. It is mighty cold here just now
To be fair, that’d make sense - but I would remove the step afterwards and clean up. I know swarf is a bugger and you keep finding it for ages afterwards.. did yours look like this or was it a lot worse (in terms of swarf)?I drilled through the plastic and metal without removing the plastic on mine. It seemed like the safest way to ensure the holes lined up as you can’t drill from the inside out through the plastic once you have the metal drilled. I suppose you could drill a pilot hole then remove the plastic but I didn’t bother
Is there any rustproofing, looks like bare edges from the pictures
I had a similar amount of swarf to clean upTo be fair, that’d make sense - but I would remove the step afterwards and clean up. I know swarf is a bugger and you keep finding it for ages afterwards.. did yours look like this or was it a lot worse (in terms of swarf)?
There is some, but not much at all. The hole under the drivers’ seat where the hot air vent enters doesn’t have a great deal on it, either.
