I've got the planar heater in mine. It does exactly what I wanted it to do. It switches on when I press the button and off when I'm finished with it and gets the van nice and warm in between. And it was half the price of the others. Jobs a good'n. I found the controls really simple to use. Been using it for 2 months now and absolutely no problems at all. My missus sleeps cold and was very impressed with the warmth it kicked out in minus temperatures in the lakes back in March
Sounds pretty positive. Did northwestdubs install externally under van? How much did you pay all in for installation?Still going really well. Only problem I've had with it is that when the heater kicks in it causes the battery voltage to drop sometimes. There's a safety mechanism built in to the heater and the fridge (dometic) that when the voltage gets too low (<10v) they shut down. This has only happened when I've had other stuff plugged in to charge eg laptop, phones, tablets so suspect it's more a problem with the battery capacity than the heater. Need a bigger battery I reckon. It could be the fridge that's causing this on the same hand when the compressor starts. It's only happened twice in 12 months. Took it back to the place I got it done (northwestdubs) and they think the same. It's not been an issue. All I've had to do to start the fridge is start the engine. To get the heater working I've given it a good run to charge the battery up or park it in the sun so the solar panel does the work. I spend 3 nights a week in the van as I use it for work so it's been absolutely hammered. The thing is on all night at the moment. Hardly uses any fuel. I've read about people having all kinds of mares with the high end ones so I'd say they were a sound bet
Is your heater internal or external?We have a Planar. It works fine and heats the van no bother.
I agree with others that the control unit is not a intuitive as it should be.
And also, my main gripe is that when I turn it off it commences its shutdown cycle, which involves keeping the fan running for 5 minutes but with no heat. It's so annoying - I just get the van nice and toasty, so turn the heater off, then it precedes to blow cold air into the van till it finally shuts down.
Is this normal?
Where is the heating air inlet?
If it’s been built with a fresh air inlet rather than as circulating it would be cold.
WHS^^^^ and if the fan switched off immediately you run the risk of warping the heat exchanger and overheating plastic components.We have a Planar. It works fine and heats the van no bother.
Is this normal?
