Weatfalia Towing Electrics - BCM Pin?
Jokermart
Can anyone confirm which pin in the Black BCM module on a 2008 T6 does the brown and red wire go to. I think its 53 or very close to it
Brown/red trace or Red/brown trace. Which circuit?
There may be more that I haven't found or less depending on your equipment but I can find Brown/Red trace at T73a (Black plug on BCM) at pin 4, 27, 42 and 54
What are you trying to connect or connect to??
thanks very much. I took the wire out thinking it was black and red whilst fitting the Westfalia towing electric and can't remember which pin it goes into. I've since put the brown and red into pin 53 as it was around there and started the van and the blower fan on the dash heating isn't running so from what you have said in must need to go to 54 not 53
