PDC retrofit - module needs coding [Resolved]
Van Buddy
204 Kombi 4motion 2017MY
I’ve just retro fitted front PDC with parts from carsystems.
PDC not working back or front. Long beep the first time you try and use PDC.
Any suggestions ?
Full Scan would be helpful.
Where did you connect into CANbus?
Full scan didn’t show anything. Carsystems instructions/loom had 2 wires that fit into 16 pin plug on original wiring to pdc module. I think it was pin 4 and 13
I was thinking of comparing the codings as it seems not communicating with gearbox. And to see which modules are on line and happy.
Actually I meant whereto it is connected in the van's CANbus as it seems to miss communication. It should be hooked onto powertrain bus (wires orange/black and orange/brown).
Have you changed the coding at all, I have a towbar on my van so that module is set up for that.
Have you added the module to the CANBUS Gateway module list?
I have got vcds but new to it. The module is recognised. I’ve got a towbar fitted with PF Jones dedicated wiring.
You got 3 of the most helpful members on the forum answering you but you dont give nearly enough information to let anyone help you
Things like this
get responses like this
Ah okay, my crystal ball is a bit cloudy today :)
now lets start again
do you have a full scan we could see please
Sorry guys, I do appreciate your help and I did miss a message from mmi.
I will post a full scan a bit later.
sippe
Thanks for your help.
Back from work now so have more time.
Here is my scan. I have the scan with the 4k module fitted if needed.
Good luck :)
  • Log-SB66 SJA-WV1ZZZ7HZHH041318-73190km-45478mi-2.txt
In module 10 select manual transmission, untick byte 1, bit 0.
EDIT: If you do not have rearview camera - also untick byte 0, bit 5.
Good luck
I believe VW has an updated software for your engine - also in the UK.
How do I go about getting the update, I guess I have to pay VW ?
Thanks for letting me know.
I'd guess VW would do that "free of charge" when van is serviced by them. At least that's how it works here in Finland.
Perhaps someone more local can confirm how it works in the UK.
