Passenger Window Not Working
NP01
Hi went to lower passenger window and nothing happens can't even hear motor noise. I've looked through the manual and cannot find any list of fuses to check before I investigate further anyone had similar problems? Drivers side still working.
Both windows share the same fuse, then each has a thermal fuse. So if the driver's window works, it's not the fuse.
Do they both work if you hold the unlock button down on the remote?
