Panel Van Fuse Layout;
Discussion in 'Electrics, Lighting, ICE, Security' started by 3crispies, 16 Sep 2018.
  1. 3crispies
    3crispies Member
    2017 panel van cant find fuse for top of dash 12v, have replaced 15a halfway on right but that was the 12v near gear shift and research found it was supposed to be Sc20 but mines different any clues''''''''
  2. Dellmassive
    Dellmassive 204 T32 DSG LWB SPORTLINE PV MY18 VCDS User Moderator VIP Member T6 Legend
    Map
    Top dash socket fuse is a 15a under seat bench
    If you have a factory leisure battery that is . . .
  3. 3crispies
    3crispies Member
    didnt remember any fuses under there, and standard panel van no leisure battery...
  4. Dellmassive
    Map
    Here my fuse.... behind the trim plastic by the loom connectors.
  5. 3crispies
    3crispies Member
  6. Dellmassive
    Map
    If your going in blind......
    You can use a multimeter or a low current automotive 12v test light......
    With the ignition on you can test each fuse in turn... in situ...
    by touching the top of the pin of each side of the fuse.... in turn.
    A good fuse will have power on both pins....
    A blown fuse will show power on only one side.
    It's just a guide as some circuits will not be powered at that moment.
  7. Dellmassive
    Map
    Have you found that fuse yet . . . . . ?
  8. 3crispies
    3crispies Member
    no luck, under seat only connectors and pulled a couple of fuses but didnt want to unplug too much......
  9. 3crispies
    3crispies Member
    will get multi meter out, the 12v was permanently live but pretty saw heard fuse pop from that area is there another set inside....
    tested all fuses are ok so must be elsewhere...
  10. Dellmassive
    Map
    Perm live....?
    you sure you haven't got another battery?
    Those sockets are ignition live unless off the aux battery.
    I'll dig out some diagrams.
    Nothing under drivers seat or passenger bench.?
  11. Dellmassive
    Map
    this is for non second battery . . . .
    so check possible fuses:
    SH31, SH1, SH2, SH3, SA8
    Socket U33 (fuse SH31) might be your one if you haven't got the second battery.
  12. Daveleannet6
    Daveleannet6 New Member
    Map
    Newbie here... had the very same head scratcher recently, seen the post and thought I could help at last, after many months of read only....
    As Dellmasive has shown, but just in case you have missed it.. from passenger door, lift up seat and remove the large plastic trim attached to the middle brace of the seat base (simply pulls off towards you, fuse should be there to the left hand side middle, 15amp (blue)
    Dellmassive likes this.
  13. Dellmassive
    Map
    Nice One @Daveleannet6 . . . . . . =]
    @3crispies is saying that he doesn't have a second leisure battery . . . . . .
    so if thats the case the schematic above may shed some light on the situation.
    this might be the bugger - Socket U33 (fuse SH31) might be your one if you haven't got the second battery.
  14. Pete C
    Pete C T30 PV 102bhp converted to camper VIP Member T6 Guru
    Map
    I may have missed this but where is fuse SH31 in the vehicle ?
    Pete
  15. Daveleannet6
    Map
    Other thing that came to mind was from a previous post when I had the issue which was a blown block fuse Sc40 20amp in the main fuse board by the gear stick?
  16. 3crispies
    3crispies Member
    is this under seat
  17. Pete C
    Map
  18. 3crispies
    3crispies Member
    Im baffled standard panel van all that is present is fusebox near gear stick and all test ok, under double seat its just connectors. Silly point read somewhere that disconnect battery to do reset. (will radio work after ?).
  19. 3crispies
    3crispies Member
    dont have it only a gap as main pic
  20. 3crispies
    3crispies Member
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
