P164B 2.0 150
turbo_scotty
Currently have a van in and out of limp mode due to flashing coil light and this fault. I've changed both sensors for genuine parts, new oil and filter, both plugs are getting voltage 7v top and 9v bottom kinda stuck anyone else had this issue with the sensors?
Welcome to T6F . =)
Let's see if we can help.
What sensor s have you replaced?
And where are the voltage readings taken from ?
What are you using to scan for codes?.... Carista?
Hey .
I’ve replaced both high pressure and low pressure green and brown
Voltage readings are taken from the plugs from both sensors
I have a Mac tools scanner and Vcds
Regards Scott
not sure im following you yet . . .
can you post the VCDS scan relating to the faults logged.?
high pressure and low pressure - which sensors? - oil?, boost?, exhaust?
Voltage readings are taken from the plugs from both sensors - is the reading Pin + Ground? or across the incoming loom?
some pics will help as they say 1000 words etc.
I've checked the voltage on both plugs both have voltage. both have earth until ignition is switched on then im guessing ecu switches to a signal feed. I've tested both and wiggled the plugs/loom around to check for breaks in the wires but both seem fine.
