P0684
Mo_baig20
P0684
Hi
I have had this fault come up and an engine light when I start the van on a cold morning. It clears and doesn’t come back until it’s another cold start in the morning. I have had all 4 glow plugs replaced and also the glow plug module. Still the same engine light and p0684.
Anyone know of what it could be?
I have a MAN TGE 177bhp Fwd biturbo 2020 DAVA engine.
A T6, or a MAN?
I would expect that the ECU still is quite similar to T6/T6.1, so
Does the glow plug controller communicate with ECU at all? You could verify the following
- What does the ECU's built-in test (under Basic Settings) "Test of automatic glow time control module" report?​
- What does the ECU report for "Glow status"?​
- What does the ECU report for "Preheat time"?​
Do the glow plugs actually heat-up? Can be verifed either actually measuring they get voltage/current or taking advantage of "Battery monitor Control Module" under 19-CAN Gateway (on MAN) or dedicated "61-Battery Monitor" on T6.
Examples of diagnostic tool measurements below
A T6, or a MAN?
MAN
